FKB Pro - Sociaal thema
The FKB Pro theme is a professional, social-media-inspired design for Discourse, featuring a three-column desktop layout and a mobile-friendly interface. While praised for its aesthetics and performance improvements (Tiago_santos), the author Don warns that it is complex and may conflict with other components. The discussion tracks extensive development to address compatibility and layout issues.
Key Updates & Features:
  • Layout & Responsiveness: Initial reports of wide layouts on tablets (Jagster) and broken category headers were quickly patched. A major update shifted the layout from Flexbox to Grid for better sidebar compatibility (Don).
  • Customization: Users requested fixed-width columns for large monitors (Paracelsus), which were added. A new feature allows custom sidebar content for visitors (Don).
  • Interactions: Support for Discourse Reactions was added as a component fix (Don). A recent update introduced Bulk Select functionality, allowing users to select topics via a floating button with specific styling for desktop and mobile (Don).
  • Topic Thumbnails: Significant improvements were made to topic image handling, including settings for height, fit (cover/contain/scale-down), and backdrop effects like blur (Don).
Compatibility & Bug Fixes:
The theme has been iteratively refined to support plugins like Right Sidebar Blocks (Don), Topic Ratings (vifyirusti), Kanban Boards (Don), and Topic List Thumbnails (We_the_Makers). Recent updates addressed stale data in the right sidebar by implementing sessionStorage caching with TTL settings (Don).
Critical Recent Issues:
The thread concludes with severe compatibility reports for Discourse v2026.4.0-latest (Ember v6.10.1). Users soul and secretheartgcn-hub reported fatal frontend crashes due to the removal of the ember-this-fallback module from core. The theme still references this deprecated module, rendering the forum unusable. Users are advised to wait for a patch or temporarily revert the Discourse version, as the theme requires migration to explicit this. bindings to function with the latest core changes.
FKB Pro is a highly modified, detailed, professional social theme, but still user-friendly. :rocket:
:warning: This theme is quite sensitive and maybe not well compatible with other theme components or plugins you use! Please test it before use. These usually need some css modification. If you have any issue please report and will fix it.
Layout
On desktop: Three column layout.
Sidebar ready
On mobile:
Rounded corners
FKB Pro has highly rounded corners everywhere by default, but I know not everyone likes it so I added some Theme Settings to make it easier to customize it.
If you don’t like rounded corners… set these value to 0.
Topic Card
Main sections
  1. Title (click goes to the last post)
  2. Excerpt (click goes to the OP)
  3. Image (click goes to the last post)
Other sections
  1. Left top: Author datas (avatar, name, username) and the date when the topic created.
    (click open user card)
  2. Right top: Category badge
  3. Center bottom: Tags
  4. Left bottom: Topic likes and views
    (click goes to OP and summarize topic if available)
  5. Right bottom: Last poster avatar, date and replies count.
    (click avatar open user card, date go to last post and replies count open reply selection)
Badges style
  1. bullet
    Screenshot 2022-07-28 at 13.20.14
  2. bar
    Screenshot 2022-07-28 at 13.17.04
  3. box
    Screenshot 2022-07-28 at 13.18.34
Category Page
Because of the limited size on center please use, one column category page styles. I made some customization on these to fit more to this theme.
Categories Only, Categories and Latest Topics, Categories and Top Topics
Categories Boxes
OR
You can use the Modern Category + Group Boxes theme component created by @jordan.vidrine
FKB Panel
On desktop: The right sidebar.
For anon visitors it is show a Welcome message. This message is same as js.signup_cta.value_prop. The header Welcome text you can change in Theme Translation.
OR
For anon visitors there is an option to enable a custom sidebar. You can add custom content to the sidebar like image and description.
For logged in users it is contains the user informations such as profile picture, statistics, badges and also use the user card image to background. Also contains some quick buttons on bottom.
Color Schemes
The theme contains two color schemes FKB Pro - Light and FKB Pro - Dark.
Color Schemes
FKB Pro - Light
  • primary #242526
  • secondary #ffffff
  • tertiary #147efb
  • quaternary #147efb
  • header_background #ffffff
  • header_primary #242526
  • highlight #147efb
  • danger #f8745c
  • success #42b72a
  • love #fa6c8d
FKB Pro - Dark
  • primary #ffffff
  • secondary #242526
  • tertiary #147efb
  • quaternary #4267b2
  • header_background #242526
  • header_primary #ffffff
  • highlight #147efb
  • danger #f8745c
  • success #42b72a
  • love #fa6c8d
There are some custom color schemes too which you can change on settings.
Custom Color Schemes
fkb-bg
  • light #f0f2f5
  • dark #18191a
fkb-header-btn
  • light #e1e5eb
  • dark #3a3b3e
fkb-header-btn-hover
  • light #d2d8e1
  • dark rgba(var(--primary-rgb),.1)
fkb-btn
  • light #e1e5eb
  • dark #383838
fkb-btn-hover
  • light #d2d8e1
More about the latest updates :arrow_down_small:
and here :arrow_down_small:
There are so many other customizations what I didn’t mention. :slightly_smiling_face:
Credit :heart: Huge thanks to @awesomerobot to created Fakebook theme and @jordan.vidrine to created Fakebook Modern theme.
With iPad it is quite… wide. I mean, really wide :wink:
That is because of there is no sidebar, I guess. Any ideas why?
I love it!
My only suggestion is to make the hamburger menu wider and then add padding
Another small one:
  • my forum doesn’t use solved-plugin
  • we don’t use badges
You know better how I hide those two :wink:
Otherwise… this theme looks really promising on desktops and mobiles (tablets are little bit problematic)
BTW — there is small layout issue with versatile banner. It pushes content below it a little bit too much to left.
Hello,
I pushed a fix to tablet view. Please update the theme. :slightly_smiling_face:
That was fast.
Much better, thanks. I got a new default theme…
Thanks :slightly_smiling_face: Yep, I think this is default. The first item is in focus when you open menu.
Yeah, I was just sugesting that there’s a bit of space inbetween them, besides that the theme looks good for how much I hate facebook and meta haha
Thanks :slightly_smiling_face: I pushed a fix for this.
I’ve added two theme settings.
I will check this.
I must be pain in the tender places :rofl:
There is one issue. Not for me, but for my top 5 contributers it is matter of life and dead — well, that was perhaps too much but they really want this.
Category settings:
It normally shows something like this (on iPad, but you understand what I’m meaning)
Your layout breaks if there is a description or name of category is longer than few characters:
Disabling show subcategory list above… solves out this, of course.
But I’m moving toward using only top-level categories and heavily relying on tags anyway (and then your theme is actually quite suitable in many ways) — so if fixing that would take a little bit too much work and/or you have something more important to do, I’m totally ok if you work with this later.
Hello, I’ve added a fix for Discourse Reactions. :slightly_smiling_face:
You can install it as a theme component.
Thanks for the report @Jagster. I have pushed a fix for this issue. FIX: Topic list category layout by VaperinaDEV · Pull Request #3 · VaperinaDEV/fkb-pro-theme · GitHub
Hello, I have pushed a fix for this. Thanks :slightly_smiling_face: Please update the theme.
Before
After
very cool theme. pls ad more post for test.
Thanks :slightly_smiling_face: I updated the OP with the theme creator preview link so now you can try it on https://discourse.theme-creator.io/theme/dodesz/fkb-pro too.
Awesome theme! If I can figure out a way to get a freaking domain and an email server ill def use this theme.
Hello,
I’ve added a new feature :tada: Now you can add custom sidebar content for visitors.
https://github.com/VaperinaDEV/fkb-pro-theme/pull/6
thank for updated this theme.
It would be so great if you develope this theme like blog (forget facebook theme :sweat_smile:)
suggestion from https://www.newsbreak.com/
I disagree :wink:
Blogish needs are different than trying to offer more SoMe-style for those who thinks Faceboom/insta/etc are the best possible UX/UI-experience.
So — out there could be a theme that looks a bit more like blog (what ever that now is meaning…). But this is just fine as it is now.
(WordPress is much more superior as blog-platform than Discourse; those are two totally different tools for different purposes…)
Hi, great theme!
The theme preview in our forum doesn’t show with 3 columns, only a one-column layout. I suspect some css problem, but still trying to figure it out.
2 questions:
  • Is it possible to have fixed width columns upon a minimum screen width (or several, using for instance media css rules) on desktop-mode? The flexible width gives me a bit of headaches in very large monitors (24 or 27’') and the “dead space” between the three columns is a bit awkward
  • Is the theme compatible with the component for right side blocks Right Sidebar Blocks - theme-component - Discourse Meta? If so, it makes the right column more useful/feature rich.
