הוספת אפשרות למנהלים/צוות לשנות נושא לפורמט Post Voting
We have added the Q&A format to our Discourse account but it is pretty hidden right now and it has been challenging to get the community to use it for their questions. Is it possible to slow admins to change a message to Q&A format after it is posted? That way we can start educating the community members about this option.
It can be similar to the option for switching topics to personal messages and vice versa. :point_down:
15 לייקים
This would be nice but how would the answers and comments be determined. I would say what replies to each other but some times they don’t reply to a posts but a topic.
לייק 1
Good point! I think that’s another level of editing that needs to be added. Just thinking loud:
  1. Admin changes the topic to Q/A format.
  2. All the current replies are changed to answers.
  3. Admin has the option to select and change the answers to comments. This is similar to how one can select the replies right now and move them to a new topic.
5 לייקים
We are looking forward to this wonderful feature. Thank you.
2 לייקים
Yes, all these option will be very useful! I hope Discourse team will implement them soon.
לייק 1
Also looking for ways to “migrate over” existing support topics into the voting format.
לייק 1
I’ll add +1 to this, such a feature would be wonderful (along with option to switch existing topics into this mode).
If I might make a suggestion - I definitely think this would be a valuable addition but I’m cognizant of difficulties converting existing topics to the Q&A format and figuring out what to do with answer comments if converting from Q&A to discussions, which may require a lot of manual work by admin-types and significantly more design/dev work to puzzle out.
One thing I think might be a middle place with a quick solution to start out is making it quick and easy to convert from one format to the other when there are no responses yet - a grace period, of sorts. Imagine the following situation:
AWESOMECOMMUNITY adds the new plugin. USER1 isn’t aware of the feature and their newly-created topic would be a perfect Q&A rather than discussion. ADMIN1 wants to convert but can’t. Even though no one has interacted with the topic, the only way to change the state is to get USER1 to delete and repost as a Q&A.
I could see value in even allowing the poster to make this change in this narrow case - perhaps they started something as a Q&A but by the time they finished their draft, they realized a discussion was more appropriate but forgot to switch the post type back. While they can delete and repost, it’s messy and could be frustrating for them.
I could see other options to avoid this second situation, such as a review phase where the user is reminded which format they’ve chosen and asked to verify it but the Discourse model is so clean and simple, adding more steps to post creation seems like something to avoid.
So, in the interest of addressing the “whoops, crap, I didn’t know/forgot about this new feature” situation, I would encourage making it possible for the OP and Admins to convert between the two post types provided there’s no answers/replies to the post. I leave it up for discussion whether comments on a question should count as “answers/replies” since they seem to be much more easily converted into discussion responses than the other possible interactions in either format.
לייק 1
אני מסכים גם לבקשה זו.
לייק 1
Note, we have these category settings that do help here:
I think it is pretty important to enable them and carve out a dedicated space for post voting.
לייק 1
Thanks Sam!
I still think a feature to convert a whole category into Post Voting mode would help those of us who are just getting started with setting up new communities.
E.g. I’m trying to set up a ‘feature request’ type voting apparatus and there’s already a lot of rich content in my existing category. Ultimately, I wouldn’t want to start that category over from scratch :slight_smile:
2 לייקים
Absolute I voted too.
I really need this feature :smiling_face_with_three_hearts:
