Developer Toolbox
The Developer Toolbox is an official Discourse theme component designed to streamline development by providing quick access to common links, actions, and settings. It’s triggered via the ` key or an optional header button (configurable via theme settings), and includes features like toggling alerts and plugin outlets, accessing themes, plugins, settings, and documentation. It’s intended for local development only, not production use.
Users have praised its utility: manuel suggested hiding the header button from non-admins — a feature now implemented by keegan. Lilly reported a broken link for “Discourse Docs,” which keegan fixed. denvergeeks noted that “Toggle Outlets” requires the separate plugin-outlets-theme-component to function [6]. Alteras and Arkshine collaborated to fix the Plugin API link, merged by keegan, who also added support for custom links via theme settings [9].
th21 inquired about Crowdin translations; Lilly confirmed it’s now available. Regarding “Toggle Alerts,” keegan clarified it hides site-wide alerts — useful for theming — though it may appear to do nothing if no alerts are present. Support, bugs, UX, and feature requests can be filed via Meta with the developer-toolbox tag.
:discourse2: Summary Developer Toolbox gives quick access to common links, actions, and settings often used when developing with Discourse.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-dev-utils
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
:information_source: For local development use only. Not useful for production sites
Features
How it works
The component is designed by default to be unobtrusive, so you trigger a modal by tapping the grave slash ` character on your keyboard. Alternatively, you can enable a trigger button in the UI by toggling a theme setting.
Once the modal appears you have access to some common actions, links and settings that you might typically need while developing with Discourse.
Settings
Name Description
show header button Show the trigger for the dev toolbox in the header panel
remove button from flow Fixes the header button to bottom right. (Requires show_header_button to be enabled)
actions close modal Triggering an action in the toolbox will also close the toolbox modal.
custom links
Translation Default
dev_utils.toggle_btn Dev Toolbox
dev_utils.modal.title Developer Toolbox
dev_utils.modal.cancel Cancel
dev_utils.actions.title Quick Actions
dev_utils.actions.toggle_alerts Toggle Alerts
dev_utils.actions.toggle_plugin_outlets Toggle Outlets
dev_utils.links.title Quick Links
dev_utils.links.themes Themes
dev_utils.links.components Theme Components
dev_utils.links.colors Colors
dev_utils.links.settings Settings
dev_utils.links.plugins Plugins
dev_utils.links.user_prefs User Preferences
dev_utils.links.text Text
dev_utils.links.plugin_api Plugin API
dev_utils.links.docs Discourse Docs
dev_utils.common_settings.title Common Settings
dev_utils.common_settings.none Select a setting
Thank you for this great component, Keegan!
Right now the header icon always shows. A small improvement could be to only show it to admins. So when browsing the site as a regular user the look is not tweaked.
i quite like this component. thank you! :slight_smile: :+1:
i just noticed that the Discourse Docs button goes to the Plugin API link instead of docs.
Thanks for identifying that @Lilly, I’ve pushed an update resolving this:
Thanks for the request @manuel, I’ve added this now:
This looks very good – I need to identify all of the outlets, but both Toggle Outlets and Toggle Alerts seem to do nothing except close the modal.
Are they supposed to display/show or highlight something on screen when toggled on?
Adding/installing this theme component in addition to the Developer Toolbox makes the Toggle Outlets button work…
https://github.com/communiteq/plugin-outlets-theme-component
The Plugin API link is not opening the file. Seems like it needs to be updated to app/assets/javascripts/discourse/app/lib/plugin-api.gjs?
Thanks, I made the PR :+1:
https://github.com/discourse/discourse-dev-utils/pull/13
Thanks @Arkshine for the fix, I’ve merged that in :tada:
I’ve also added a few updates (fixes/modernizations) as well as a new feature where you can now add custom links by defining them in the theme setting:
Can we submit translation for this component on crowdin? I didn’t find the entrance to it.
Hi @th21 thanks for letting us know. I have added it as a translation project in Crowdin.
What is the expected result of “Toggle Alerts”? clicked and nothing happened
It is intended to hide any alerts you have on your Discourse instance. If you have any alerts on your forum like this:
It will hide it from the page. It’s quite useful for example, when theming and you want to temporarily see the page without any alerts.
