This doesn’t seem to be working at all.
I was wondering if I could upload, similar to when we upload tags. So in this case, the CSV would be:
Hello World,Hello-World
File uploads successfully, but no words are added.
Hi @ncaming215 ![]()
Sorry for the delay in testing this one out. I’ve given it a go on my test site and I also cannot seem to get the bulk upload to accept my tagged Watched Words.
My (very basic) step-by-step:
dog,dog-tag)I tried both with new tags as well as existing ones, as well as a txt file in case that made a difference, but the result was the same.
The other dual Watched Words seem to work as expected (Replace and Link).
Thanks for confirming! Yeah, I painstakingly added over a hundred Watched Words, but since they’ll change annually, any fix to this would be widely appreciated. ![]()
text one,existing-tag-1
text two,new-tag
text three,existing-tag-2
I think this issue is happening only when the replacement tag is not exists. If I upload the csv file with the above content then it adds “text one,existing-tag-1” and “text three,existing-tag-2” but skipping the second one. It doesn’t raise any errors and adds the watched words successfully if the all the tags in file are already available.
I will push a change to create tags if not exists.
Hi!
Anything happened with this?
I did not succeed in setting watched tags from file, even though some of the tags exist.
Would it be possible to at least not show a “Success” message, or alternatively show a count of the number of added watched tags?
Thanks!
Thanks for following up here!
We have noted this issue and added it to our backlog to fix. While we cannot give you a timeline on a fix at this stage, we will follow up here once we have worked on it and made some progress.
