De Discourse-zijbalk gebruiken
:bookmark: This is a comprehensive guide explaining the various features and functionalities of the Discourse sidebar, including how to customize it for your needs.
:person_raising_hand: Required user level: All users
The sidebar in Discourse provides quick access to various forum features and allows for easy navigation. This guide will walk you through the different sections of the sidebar and how to use them effectively.
Primary menu
The primary menu contains essential navigation links:
  • Topics: Shows the latest posts on your forum.
  • My Drafts: Displays dynamically when you have a draft topic or reply.
  • More: Expands to show additional options.
  • Groups: Takes you to your groups page.
  • Users: Shows the user leaderboard (if enabled).
  • Badges: Displays the badge gallery (if enabled).
  • About: Provides information about your forum.
  • FAQ: Links to your forum’s FAQ page.
Administrators will also see Review and Admin options for moderation and site management.
:bulb: There may be additional buttons if you have plugins installed. For example, if you have Cakeday installed on your forum, Anniversaries and Birthdays will appear in your sidebar.
Categories and tags
This section displays categories and tags for easy access. To customize:
  1. Click on the pencil icon to access sidebar settings.
  2. Use the plus icon to add or remove categories and tags.
  3. Click on “All categories” or “All tags” to view the complete list.
Messages
The Messages section allows you to:
  • View your inbox
  • Compose new messages by clicking the “+” button
  • Access multiple inboxes if you’re in different groups
Chat
If your forum has Chat enabled, you will see the Chat section, which includes:
  • Channels: View and manage chat channels
  • My Threads: Manage threads you’ve created
  • DMs: Access personal chats
To start a new DM, click the “+” button next to the personal chat tab.
Customizing your sidebar
You can personalize your sidebar experience:
  1. Go to your user preferences.
  2. Find the “Sidebar” section.
  3. Adjust settings for categories, tags, and how new posts are displayed.
Creating custom sidebar sections
To add a custom section:
  1. Click the “+” button at the bottom of the sidebar.
  2. In the modal, customize the icon, name, and links for your new section.
This feature allows you to create personalized navigation options to improve your productivity.
Mobile access
To open the sidebar on mobile devices, tap the hamburger menu icon in the top right corner, next to your profile picture.
Additional notes
  • The sidebar layout and available options may vary depending on your forum’s settings and installed plugins.
  • Administrators can create global sidebar sections visible to all forum members.
  • Custom sidebar sections are an experimental feature and may be subject to changes.
:writing_hand: This document was originally written by @twofoursixeight.
I’ve just noticed a brand new sidebar, and some changes to the sidebar here on Meta. The guide uses an older version of the sidebar.
That’s the experiment one:
That’s the documentation sidebar:
Interesting, can’t wait to see more changes to the forum being made and how this forum becomes more and more modern by the day.
Things must have changed because there is no sidebar tab in my user Preferences. Instead there’s navigation menu and it doesn’t allow me to customize the side bar, the only options available are:
Navigation
When a topic list in the navigation menu has new or unread items…
Link to the filtered list
Show a count of the new items
  • How can a user customize the sidebar now?
  • Is there a way to customize the sidebar’s first part (Topics, My posts…)?
  • Is there a way to customize the sidebar at an admin level for everyone?
navigation menu is the sidebar
By using the edit buttons at the sections and the + to add a custom section.
Admins can add and remove links by clicking “more” and “customize this section.”
Changing the first section changes it for everyone. When you create a new section, you can choose to show it for everyone. The default tags and categories can be configured in the site settings. You can search for default navigation menu to find them.
The sidebar on meta seems to be context-sensitive, for example if I’m in an AI topic, other admin or AI links are shown in the sidebar. I don’t see how to configure this. Is it experimental?
That’s a sidebar for documentation:
There’s been more changes lately to the sidebar, that I wish to address, these include the “My messages” button which takes you to your messages, and an Invite button used to quickly invite others? (Upcoming events and docs are part of plugins.)
This also includes the 2024 redesign of the sidebar.
On Meta, there’s also a filter button and a button taking you to your drafts.
I forgot to mention the Messages section was replaced by the trusty “My messages” button on the top of the sidebar, this is what it used to look like:
Now it’s just this: image
This doesn’t seem to exist anymore; the guide should probably be updated.
Hello everyone :waving_hand:
I’m customizing my Discourse forum and noticed that the sidebar appears open by default whenever a user accesses the page.
What I’d like is for the sidebar to be closed by default and only appear when the user clicks the hamburger icon.
What I’ve already tried
  • I’ve adjusted user preferences and theme settings related to the sidebar.
  • I’ve tried using CSS (display: none) and JavaScript (onclick on the hamburger button).
  • The sidebar does hide, but I haven’t been able to integrate it in a way that works like Discourse’s native behavior (opening/closing without breaking the layout).
Mijn forum hier, en op elk forum dat ik gebruik, is altijd gesloten. Het zou zijn staat moeten onthouden. Opgeslagen in een cookie, denk ik.
In this topic Can I default to a hidden sidebar? a theme component was shared that closes the sidebar by default. It was created 2 years ago, so I don’t know if it still works but you could try. Even if it no longer works, it may be helpful to take a look at the approach.
