Homepage Toggle
:information_source: Summary A theme component that toggles between two homepages.
:hammer_and_wrench: Repository GitHub - josephclaytonhansen/discourse-homepage-toggle · GitHub
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
This Discourse theme component adds a toggleable homepage in the header, allowing users to jump between two pages that can be set in the theme component settings.
  • It uses the primary and tertiary colors from your theme automatically.
  • You can set the icons (and URLs) for each side of the toggle in the theme component settings.
This was created for an art forum to toggle between an art-focused homepage gallery and a more traditional forum view. The default icons (a gallery and a list) reflect this by default but they are customizable.
Tested on Firefox, Chrome, Safari, and Edge- no issues found. For desktop only- future updates may include a mobile version as well
nicely done. i like this. :clap:
When using that function I get this error
It works when using the url manually
Seems like a useful component for those that want an art/picture focused home.
However: The gallery view in Customization > Theme can also be used for a similar purpose.
And FYI for every beginner: icons (list or grip-verticaletc.) must be added on admin setting svg icon subset.
It looks like to be desktop-only, right?
I missed that last sentence totally :man_facepalming:
I think there is a tag for such situations, like desktop
This appears to be broken… what would it take to repair it?
the decorateWidget is deprecated (edit: in the header)
Specifically: modifying the header using decorateWidget was deprecated, and is now impossible. More details here:
(decorateWidget itself still exists for now, and is still a supported way to customize some parts of the Discourse UI)
I’ll mark this theme-component broken for now
