קישוריים קצרים של Amzn.eu לא שונו על ידי תוסף השותפים
סיכום מבוסס בינה מלאכותית
Users reported that the Discourse Affiliate plugin does not rewrite newer Amazon short domains like amzn.eu and a.co when used inline, though they work correctly in onebox format. jrgong first raised the issue, and zogstrip invited contributions. Ahmed_Gagan offered to submit a PR, but Overgrow ultimately did so, adding support for a.co, amzn.eu, and amzn.to, with a new plugin setting for affiliate_amazon_eu to handle regional variations. Canapin confirmed oneboxes work because they resolve redirects, while inline links do not — a distinction Overgrow addressed in the PR. j127 confirmed the issue persists for inline a.co links even after updates. Heliosurge and others noted the growing use of short links across Amazon regions. The fix was well-received, with Richie thanking Overgrow for the contribution. The PR is available at: https://github.com/discourse/discourse-affiliate/pull/79.
It seems, that the fairly new amzn.eu shortlinks are not rewritten by the plugin, does anyone have the same issue?
2 לייקים
@rishabh any plans to add amzn.eu Link support to rewrite the links as well?
3 לייקים
I don’t there are any plans at the moment, but pinging @zogstrip to see if he has any thoughts about this addition.
4 לייקים
I’d be happy to have the plug-in support this new domain.
@jrgong would you like to make a pull request to add support for this domain?
4 לייקים
I am not a developer, so I won’t be able to do that unfortunately. But maybe @Ahmed_Gagan can do that :slight_smile:
3 לייקים
Hi @zogstrip
Yes I can make a PR for the fix.
7 לייקים
I hope that in the future I can support many other platforms besides amazon, like I deploy affilate with digital products and add custom UTM feature when there is an outlink from my website.
2 לייקים
Hi wondering if any progress on this? As it seems that amazon.ca uses short links. Imagine that most Amazon sites are now using short links.
Thanls
a.co links are used by default when sharing from amazon.com as well now.
From European countries, it uses amzn.eu.
2 לייקים
I used a.co and amzn.eu here with the plugin enabled:
It created oneboxes with full links and with the attached affiliate tag. So I guess it already works, and nothing has to be done?
2 לייקים
On my site the a.co links are inline with other text and don’t get the affiliate tag added.
Edit: just to be sure, I updated everything and rebuilt the HTML for a post that has a.co in it, and the tag isn’t added. I tried both inline and onebox, but the onebox doesn’t appear. The link is in this format: a.co/d/some-chars.
2 לייקים
Does it work if you disable the affiliate plugin?
I will need to retest. So it expands the short link and adds the affiliate code ?
Even on Amazon I find it often takes a couple of triesto get the full link copied to clipboard with the affiliate code.
The reason it works fine with the onebox and not with inline links is that they are treated differently. In order to create a onebox, the system first goes through all redirects to fetch the “final” unshortened URL. And because the final URL is recognized by the affiliate plugin, it gets rewritten. Unfortunately, the inline links do not.
I’ll submit a PR to affiliate plugin later with the support for
a.co
amzn.eu
amzn.to
Any other short domains come to mind?
From my observations, a.co and amzn.to are both short for amazon.com, so IMHO it would be safe to use affiliate_amazon_com tracking code.
amzn.eu translates to amazon.de for me, but I’m not sure if it might redirect to, say, amazon.fr for you. To accommodate both, I’ll add a new plugin setting for affiliate_amazon_eu.
Update:
PR submitted:
8 לייקים
Works great, thanks for putting some time in to this @Overgrow :clap:
4 לייקים
