משדרג מנהלי קטגוריות
:information_source: Summary Allow most moderator level actions for category moderators
:hammer_and_wrench: Repository Link Github
:open_book: Install Guide How to install plugins in Discourse
Update - May 6th, 2024
The plugin has been updated and tested to be working with Discourse v3.2.1 which is currently the latest stable release (non -beta). We aim at supporting future stable releases only, which means that if you are on a -beta version, chances are that this plugin will not work.
On the GitHub link for the plugin, the readme explains how to be sure to be on v3.2.1.
We have just downgraded from the latest -beta to v3.2.1 and the only issue we have encountered is that the sidebar get a little crazy. To fix it, simply logout and login.
With this update we also included the “change ownership” to the actions available to category moderators as it was requested some time ago.
Discourse Version Supported
v3.2.1
Feature Request for Discourse
A Feature request to incorporate these functions is open here. Feel free to support it, if you think it would be useful to include these changes in the core Discourse functionalities.
Features
Since we started using discourse we found the actions available to category moderators to be lacklustre. Most basic content actions are limited (Set slow mode, add staff colour/notice, etc) when there isn’t really a reason in our opinion.
Thus we decided to try our hand and create a plugin that would grant most of the content-related moderation powers to category moderators, when they are in the category they have been assigned to.
These are the only exclusions:
  • Category Moderators cannot act on users - Suspend, Silence, Change TL, access admin view on users are still reserved to regular moderators
  • Grant Badges - requires some admin permissions that we preferred not to mess with.
  • View moderation history - requires some admin permissions that we preferred not to mess with.
  • Convert Topics to PM and vice versa - We considered this action something of a niche case and preferred to leave this to the regular forum moderators
Configuration
Simply install the plugin as you’ll do for any other and click the checkbox in the settings to turn it on.
CHANGELOG
  • Initial Beta Release
  • Updated version working with Discourse v3.2.1
TODO
  • Detailed settings view that allow to choose which actions to enable for category moderators
16 לייקים
You don’t see the reason at all, or for your instance?
We sometimes use it on meta. For example, if a plugin or a theme/component originally developed by someone who doesn’t work on it anymore is transferred to someone else, then we change the author to the new maintainer, or to @system, depending on the context.
2 לייקים
Clearly I worded it badly. Fixed now. In the TODO in fact is the possibility to enable that feature as an option.
In our community, that would simply become a wiki post so that everyone can contribute on it. It makes sense in the example you specify but for our forum, the only close case would be a guide for something (self hosting something using raspberry-pi, a guide to a game, a list of events for a band, etc etc)
3 לייקים
Here’s an example use case: with the WordPress plugin, users need to be individually configured with a Discourse username — even if SSO ensures they are 1:1. If someone forgets or misconfigures the WordPress side, the post ends up owned by “system”.
Having WordPress moderators be category moderators for the blog comments category would let them take care of this (and, of course, moderate comments).
Is this big use case here that you want category moderators not to be tl4 ?
I am very open to simply improving core here
9 לייקים
I, at least, would like to make a distinction between:
  • recognized by a discussion community as a responsible, productive, constructive participant, and
  • has responsibility and power over a certain area by virtue of role (a role possibly entirely unrelated to general participation in discussion)
TL3 is an automated version of the former, and TL4 seems to me kind of like the “you’ve got tenure!” version of that.
Category moderator is (or should be!) perfect for the latter.
3 לייקים
TL4 are forum wide. In our mind, a category moderator should have access to all tools a moderator has but restricted only by the category itself.
It’s a personal opinion but it really don’t make sense to us that users with an high TL have more power than category moderators when it comes to moderate a category.
TL4 in my opinion are good as they are as they can actually moderate forum wide but not act on users.
They are basically trusted users, recognized by the community to protect and foster it, without the risk of having them go nuts one day on other users account.
Category moderators, again, in our views, should be able to do what a moderator does, but in their own category. This include even banning people but that is on an entire other level of complexity.
What I was thinking is creating a group of users like “banned_from_categoryslug”, that category get assigned with read only to the category and the users added to that.
Alternatively, just extend users using the dedicated table in the db in which you add a user_id, category_id and a datetime. Every time a user access a topic, a check is run to see if he can actually interact with it or not.
The benefit of going for a group-based route is that there is a form of UI already implemented for admins and forum moderators to eventually lift a ban. The other approach would require to also develop a dedicated view but would allow for more flexibility (see ban expirations, etc)
8 לייקים
So, what benefits are added?
Moving topics to other categories controlled by the group?
Reviewing flag queue?
לייק 1
I’m not sure this is a direction that Discourse want to go in, but if category moderators had this kind of power, it would open up the possibility of using categories as forums within a forum. That would be great from my point of view.
7 לייקים
I believe Group Owners can remove people from the group, which would then remove their access to the category (if group-restricted). So perhaps a combination of group owner + category moderator would work for this?
3 לייקים
Could you please clarify exactly what this changes for Category Moderators. Thank you so much.
Given the statement “these are the only exclusions”, everything on Trust Level Permissions Reference where the Category Moderator column says “TL” or is blank would turn to :white_check_mark:, except granting badges, changing ownership, and user-account actions.
I’d really love to see this have more granular control — or better yet, for that granular control to be not a plugin but baked in. For me, lack of the ability to change ownership (ironically one of the exclusions, I know), is the big deal — but obviously not for everyone.
3 לייקים
100% agree. :heart:
This can work indeed. I have created a setup using this model and was apart of the html/markdown topic on the Display message if cannot post. To have it generate the message with a link to message group owners.
While this works a better option would be to add a ban\silence list option with time options to group owner. A problem user can then be banned from a group access category. While having an option to keep group unrestricted to join leave. Even in a restricted group this listing could maybe be extended to a notify user has a ban from group with ban note.
Note We could likely start a Contribute > Feature request to extend group functions to enable a reddit like subforum system using category mods.. as @simon seems to have an interest as well.
2 לייקים
Believe me, I would love that as well from Discourse itself. It’s been incredibly annoying to have someone work on the style of the forum but having to test the changes myself because I couldn’t just give FULL ADMIN to a person that was supposed to work just on css and visuals.
We can look into this. Admittedly something that we simply neglected because we didn’t think of an application (regular forum-wide moderators can do that eventually)
Overall, I would gladly retire this plugin if Discourse implemented a more granular control and would love for category moderator to be able to ban people from their category only, but alas, it doesn’t seem a priority or something they are interested in at this time.
לייק 1
I don’t think I can find the Contribute > Feature request for these changes? If you could link to it in the OP it may help get more attention to it?
2 לייקים
Might be an idea for me or someone else start the extending groups.
ie
Atm I use req to join groups & template plugin to have a ban list to reference.
Apparently, one of the latest changes
New Revise option for queued posts
Moderators can now select “Revise…” as an option when reviewing posts queued for approval. A PM will be sent to the user with the reason for requesting a revision and optional comments so they have an opportunity to improve their post when they resubmit it.
Did something more than just add a new option because the plugin stopped working. It’s not breaking discourse as far as we can see, but the additional options are not available any more. It’s always fun when someone decide to refactor lots of stuff on top of adding a single new feature :smiley:
We are trying to look into the code again to figure out what has been changed.
לייק 1
My understanding was that someone from the devs or close to them said that it wasn’t a priority / direction in which they were intending to go but maybe I am mistaken. I’m just passing by now, if anyone want to open the feature request, feel free to cross-link this topic so it appears in the links at the top or @ me and I will update the first post.
לייק 1
You got this from the CEO, so I’d say that was encouraging:
Probably worth a Contribute > Feature request or two if you did want to see them added to core.
3 לייקים
