게시물 목록 작성자
:information_source: Summary Makes the topic author appear instead of posters and allows changing the placement of the author column in topic list pages.
:hammer_and_wrench: Repository https://github.com/discourse/discourse-topic-list-author
:eyeglasses: Preview Preview on Discourse Theme Creator
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
This theme component makes the topic author avatar appear in topic list pages (ie: /latest /new /unread /top) and the category homepage (if using a category view with topic list).
There are also settings to change where the author column appears for topic list pages - left, centre or right.
This component works with both desktop and mobile views, although the centre avatar placement only shows in desktop view.
Screenshots:
Author avatar in default (center) column placement
Author avatar in first (left) column
Author avatar in last (right) column
Author avatar on a category homepage topic list
Mobile view with topic author avatar in first (left) column
Mobile view with topic author avatar in last (right) column
Settings
:discourse2: Hosted by us? This theme components is available to use on our Pro, Business, and Enterprise plans.
Last checked by @Lilly 2025-06-14T13:50:43Z
23개의 좋아요
Hi Lilly, not that you need more to do :wink: but I have another issue with topic thumbnails, the avatar is now showing up twice:
1개의 좋아요
yea the refactor possibly makes this component incompatible again. I’ll see if I can come up with a workaround of some sort. probably need to hack some CSS to make these two components work together if it’s possible.
3개의 좋아요
question: why do you use this theme component? it appears as though topic list thumbnails is using the topic author avatars already because it previews from the first post (OP), (although there are a lot of settings in that theme component). Are you wanting this to only apply to specific categories that Topic list thumbnails isn’t using?
1개의 좋아요
Great question :grin: Yes, I have some categories that are not using thumbnails.
2개의 좋아요
edit: @davidkingham - you can use the old branch still
4개의 좋아요
This component is now official and the repo link in the OP has been updated. Please use the new repo link to re-install this component to avoid any errors. The old repo will not be maintained going forward and will eventually be archived.
4개의 좋아요
I’m a little slow to respond :grimacing: but unfortunately the old branch isn’t working either. On the categories+latest page it shows the last poster not the author. There’s no chance of making this compatible with Topic Thumbnails now that it’s official? :folded_hands:t3:
1개의 좋아요
Hi, this component causes a weird indent on my site:
Any suggestions?
2개의 좋아요
I fixed this by adding the following to CSS custom code for my theme:
.above-latest-topic-list-item-outlet, .author-avatar-connector {
    width: 0px;
1개의 좋아요
It would be great if this component mirrored the new core behavior and removed links when hide_user_profiles_from_public is enabled.
1개의 좋아요
Would it be possible to make this TC be applied to just specified categories, in the same way as Topic Thumbnails and Topic Excerpts?
Workaround
I’ve found that this CSS (when added to the Desktop tab of a theme component) works nicely for my use-case by turning off the functionality for all of the categories except the one I want it to work in:
body:not(.category-ask-the-candidates) {
    .topic-list .posters {
        display: table-cell;
    th.author, .custom-author-column {
        display: none;
If you want to use this yourself, simply swap the slug of your specified category(ies) in.
2개의 좋아요
PR을 받아주시나요? PN 대화에서 해당 기능을 제거하는 것이 좋은 개선 사항이 될 것 같습니다.
