이 Discourse 포럼에서 어떤 테마를 사용하나요?
hi there friends,
I am exploring Discourse and are wondering if the following websites use a specific theme or if they are custom made. If custom made what would be a good starting point to recreate them ?
The first one is the following: OpenAI
https://community.openai.com/
The second theme has a split in the middle. Is this a specific setting or part of a theme I haven’t found yet ?
https://forum.solana.com/
The following two are quite similar also having a split theme. Anyone knows which themes they are build on ?
https://community.developer.atlassian.com/
https://discourse.opensourcedesign.net/
The next one also has a split:
https://blenderartists.org/
Lastly, how does one make such a powerhouse as Epic Developer Community Forums
3개의 좋아요
hi @Remo_van_de_Sande :wave: Meta에 오신 것을 환영합니다 :slight_smile:
이것들은 커스텀처럼 보입니다. 하지만 위쪽 것들은 제 것이나 Meta의 것과 크게 다르지 않으며, 몇 가지 차이점이 있을 뿐입니다.
Customization > Theme 카테고리에서 이 중 몇 가지와 유사한 것을 찾으실 수 있을 것입니다.
분할 뷰는 관리자 설정의 desktop category page style에서 catergories and latest topics 뷰입니다. Meta에는 이 뷰가 있으며, 제 포럼에도 있습니다.
4개의 좋아요
I can only comment on the one by OpenAI as I was on the site when it was being created and transitioned to as the default theme.
Yes it is a custom theme and while I know who created it, won’t mention their name but perhaps they may find this and contact you or even respond here. :slightly_smiling_face:
2개의 좋아요
I believe the admin of Blenderartists here’s a regular member of meta: Profile - bartv - Discourse Meta. You can probably ask him directly :slight_smile:
The epic theme is a heavily customized one, maybe with custom plugins as well.
4개의 좋아요
This is a heavily customised forum. Something like this will use plugins as well as theme modifications.
This is something that our partners can help you with; Discourse can help too of course, if you are on the Enterprise plans :slight_smile:
7개의 좋아요
As mentioned, most of the sites listed don’t deviate dramatically from the standard Discourse install (the exception being Epic, which has hundreds of hours of customization done at this point)…
There are a couple other off-the-shelf components that are similar to what’s used here:
5개의 좋아요
Thanks for the tag @EricGT
I would gladly point you to the OpenAI theme, but unfortunately that’s a private theme so I can’t share it.
But as Lilly said, those aren’t terribly difficult to recreate, so a good starting point would be to familiarise yourself with this excellent guide if you haven’t yet.
And you’ll be customising in no time!
5개의 좋아요
Hi there Lilly, thank you for the pointers but Im having trouble finding those components you mentioned. Are they found on GitHub or Im I overlooking something hm
1개의 좋아요
The split views is a site setting, not a component :slight_smile:
You’ll find it under community.example.com/admin/site_settings/category/basic
7개의 좋아요
li love how Meta changed it to boxes with subcategories right after i posted this :joy:
then they changed it back… mind games i tell you :upside_down_face:
9개의 좋아요
It takes a bit of technical knowledge, but you can grasp useful information about customizations with the browser’s developer tools. In Chrome, F12 → Sources.
You have the list of the loaded files and can find stylesheets, themes and components javascript. Looking at the CSS and JS code here can sometimes give you clues, as well as looking directly at the page’s HTML code.
You can also see a comprehensive plugins list:
6개의 좋아요
Hi Bas. As a techie I’m feeling like an idiot that I can’t set this up proper ha.Whatever setting I change doesn’t actually get applied to my forum. Might I be overlooking something ?
Looks like you have a theme that is overriding stuff.
If you enable safe mode (go to /categories?safe_mode=no_themes), it seems to work just fine :slight_smile:
2개의 좋아요
hm I am baffled why I can’t get it to work. For me safe mode was already enabled by default.
I’ll send you a pm so I can share some screenshots :slight_smile:
3개의 좋아요
This is an old topic but is Unreal Engine’s Documentation possibly a custom plug-in / theme?
그들은 우리의 고객으로 등록되어 있습니다.
그들을 위한 우리의 작업에 대해 특별히 언급할 수는 없지만, 그 정도 규모의 대부분의 고객은 커스텀 플러그인과 테마를 사용 중입니다. :slight_smile:
