יצירת קישור להתחלת נושא חדש עם מידע מלא מראש
:bookmark: This documentation explains how to create a link that starts a new topic in Discourse with pre-filled information.
:person_raising_hand: Required user level: All users
Sometimes you may want to provide users with a link that opens a new topic composer with certain information pre-filled. This can be useful for various use cases including bug report templates, feature requests, or standardized posts.
Constructing the URL
Base URL
To compose a new pre-filled topic with no extra information, you append /new-topic to your site URL, like so:
https://discourse.example.com/new-topic
Clicking on this will open up a blank new topic composer for any logged-in user (if not logged-in, you’ll be prompted to signin/signup before then opening the composer).
Additional Parameters
While a link to open a blank composer can sometimes be useful, the main strength of this feature is the ability to pre-fill the composer with extra information.
To do this, you can add parameters to the base URL:
https://discourse.example.com/new-topic?title=topic%20title&body=topic%20body&category=category/subcategory&tags=email,planned
This will open a composer window pre-filled with topic title, body, category and tags.
Breaking down the link / URL to show the available options, we have:
  • Base URL: https://discourse.example.com/new-topic
  • The ? URL operator to add the different options
  • Topic title: title=topic%20title
  • The &, used each time when including another parameter
  • Body: body=topic%20body
  • The category and subcategory separated by a slash / if you want to include them: category=category/subcategory
  • The tags separated by comma(s) , if you want to include multiple tags: tags=email,planned
Each of the parameters is optional and can be mix and matched depending on your desired end result.
As an alternative to using the category/subcategory name, you can specify a numeric category_id instead, like:
https://meta.discourse.org/new-topic?title=topic%20title&category_id=3
Example
You can try this here on Meta:
https://meta.discourse.org/new-topic?title=topic%20title&body=topic%20body&category=support/wordpress&tags=wordpress
:exclamation: Though please don’t actually create the topic :slight_smile: For a more hands-on explore of the feature use our demo site, try.discourse.org
Using Browser DevTools
Open the browser console (F12 → Console) and use the built-in URLSearchParams to build the URL — it handles all percent-encoding automatically:
const base = 'https://discourse.example.com/new-topic';
const url = base + '?' + new URLSearchParams({
  title: 'My topic title',
  body: `Body text here...
supports multi line`,
  category: 'support',
  tags: 'bug,urgent'
console.log(url); // copy this url
Using a pre-filled URL with Featured Links
This feature also supports Featured Links, provided that the body parameter is not also included.
:information_source: The URL must be URL encoded for the link to work.
For example, to create a topic with the following URL https://www.xkcd.com/556, the link will be:
https://meta.discourse.org/new-topic?title=https%3A%2F%2Fwww.xkcd.com%2F556
Best Practices
  • w3Schools HTML URL Encoding Reference is a good resource to find what text characters are encoded as in the URL. If you have a lot of text to add, there is also a text-to-URL converter in the ‘Try It Yourself’ section.
  • Always URL encode the parameters to avoid issues with special characters.
  • If you’re unsure about the category ID, you can check it by looking at the number in the category URL. (eg. https://meta.discourse.org/c/documentation/using-discourse/126)
  • Test the pre-filled links to ensure they work as expected.
:information_source: It is not currently possible to have a pre-filled link that opens a composer to reply to a specific topic.
Additional Resources
89 לייקים
Start creating a new topic via link?
Link that pre-populates the composer?
Fill in post for user?
What is the best way to integrate member applications?
Open Composer with Prefilled information
Unlisted categories
URL to set up new topic and category, tags
Topic-specific reply template
Problem in sso redirection for compose a new pre-filled topic via URL
Pre-filled topics don't recognize subcategories anymore
Link to create a new topic with parsed values in GET-method data?
Link to New Topic?
Rename @discobot's start new user command
[PAID] extra input fields for new topic
How to "replace" +New Topic with a custom button that brings up the composer
Add one button for topic create with pre-filled content without composer or API?
How Coinbase Uses Discourse to Educate Customers and Improve SEO
Bookmarklet or chrome extension for posting links to a Discourse
How to add a "button" which composes a pre-filled topic
Link to start a topic with a pre-filled attachment file
How to create a post clicking a link?
Is there any link to open composer (for hyperlink)?
"push" sso users to discourse?
Post commits via webhook inside a topic as reply
Was this Article helpful? Yes or No
Category-specific "new topic" email address/url in notification email?
Onboarding: Discobot, automated messages, other options?
Deep link to new topic or account creation
Alerts that react to the user
Feedback form / reporting bugs
How to have a reply link with pre-filled information?
Create a link that will open the editor with a specific category and a specific tag
Start a topic by pasting a link (like Reddit)
URL for "Sign Up" or "Create Topic"?
Link to "Create new topic" and passing tag and category with query var?
Opening a reply window via URL
Prefilled composer link generator
Placeholder Forms
Direct link to composing a comment?
Creating pre-filled personal message links
Oneboxing not working when starting a topic with pre-filled information
Impossible to copy heading links
Is there a way to link directly to the editing screen?
Eu tenho um fórum, mas não sei se ele está bem organizado o suficiente
Upcoming Events Extra Buttons and Enhancements
Directly linking to new-topic not working when default list filter = no sub categories
Discourse Templates
How to make all users who sign up or accept in invite go to a specifed category(with post composer open)
[Solved] In plugin: opening the composer without changing the route
Any Direct URL To New Topic Page?
Have url for creating topic with specific title
Topic Templates
Using topic templates for categories
Is there a way to make an input form for structured data?
Create new topic in category with specific tag via URL
New Topic Create URL is not working for Subcategory
URL to start new post
How do I create a link which opens Create Topic?
Open new topic composer in a separate window
Gitter: Post notifications to chat, post transcripts to forum
Chrome/Firefox extension "Share to discourse"
How to add%{post_url} in customize URL
How to auto set topic title?
How can I create a new topic in Discourse via a link or direct the person to the topic if it exists
Create new topic via URL and set tag or category
Wording for private/secure categories
There is a LOT of technical heavy lifting happening here that makes this a little unacceptable to mortals; I bet we could make a “helper” webpage that allowed people to generate these links easily.
The equivalent of this might be a nifty little project for someone to implement:
import urllib
site = 'meta.discourse.org'
title = '''My special checklist'''
category = 'todo'
tags = ['tag1', 'tag2']
template = '''\
# Important!
Do these things:
[ ] thing one
[ ] thing two
query = urllib.parse.urlencode(dict(
    title =    title,
    category = category,
    tags =     ','.join(tags),
    body =     template,
print(f'https://{site}/new-topic?{query}')
prints this link
5 לייקים
Thanks for the idea! It inspired me to create Prefilled composer link generator
6 לייקים
Oh! That’s a great implementation idea. Good work!
4 לייקים
6 posts were split to a new topic: Support creating pre-filled topic links
