Zwevende citaatknop in chat?
A recent Telegram update has caught up with a feature that Discourse Chat has long had (but is not convenient enough yet): quote in chat.
Telegram
New in version 4.11
• View full statistics in your channels and group chats.
Replies 2.0
• Quote parts of text in replies.
• Reply in another chat.
• Add quote formatting.
Link Previews
• Choose preview position.
• Change media size.
• Select link to preview.
Name Colors
• Change your name color in Chat Settings.
• Customize quotes, link previews and replies to your messages.
Code Blocks
• Add nice looking code blocks with syntax highlighting.
• Copy full code block by click on its header.
• Send a highlighted code block using ```language syntax.
Currently, we have to select the message, click copy, and then paste it into the chat box, which seems like a lot of steps. Since we have a floating quote button for posts (below), would it be great to have such a floating button for discourse chat?
I love to use the buttons that appear when selecting a certain text. You can click on Quote, Copy Quote or Ask AI. Unfortunately this is not possible in Discourse Chat right now.
Steps to quote in a topic right now
  1. Select some text and click on the button and you’re done.
Steps to quote in Chat right now:
  1. Click on this button:
  1. Click on Select
  1. Go to the left and select the messages in Chat:
  1. Go to the bottom and click on Quote in Topic or Copy
afbeelding
Problem
Right now everyone in our team just makes a screenshot from a Chat. They paste the screenshot in a topic. This is a waste of webspace.
Solution
It would be very useful if selecting text inside a Discourse Chat triggered the same quote buttons as in topics. It should have the same buttons: Quote, Copy Quote and Ask AI.
Thanks for considering this feature request.
Feel free to close or merge this topic if a related topic already exists. I searched if someone else already askes this question, but could not find related topics. Search results for 'Select and Quote Chat Text into Topics' - Discourse Meta
Love this part:
I’m also curious to consider whether there are other ways we might make the existing feature more discoverable, as a possible alternative to what your proposed here.
I think this was also suggested here too:
Thanks for linking to a similar topic. Feel free to merge the topics.
Keep in mind that this might conflict with the Principle of Least Astonishment.
To be honest, I expected a floating quote button to appear when selecting text in chat, since it’s also available in topics. But maybe it works different in Chat because messages are short sometimes and it is difficult to implement a floating quote button in Chat because of this.
If adding a floating quote button in chat isn’t feasible, I’d hope for an alternative that takes no more than two clicks / actions / shortcuts. Right now, creating and pasting a screenshot is actually faster.
  1. Cmd+Control+Shift+4 → screenshot to clipboard
  2. Cmd+V → paste in composer
:index_pointing_up: make sense
Merging…
Thanks for merging. Could someone of the Discourse team change the topic title for this feature request, so that it not only involves Quote, but also Edit, Copy Quote and Ask AI? For example, you may change it to:
Floating buttons in Chat when selecting text (Quote, Edit, Copy Quote and Ask AI)
One more thing is that you can only select and quote from one reply at a time inside topics. In Chat it would work better if you could select and quote multiple messages at once via the floating buttons. Because chat messages are often short, and I can see that most of the time people in our team select (or share a screenshot :slight_smile: ) of multiple messages from Chat.
More steps to quote
In my original post I’ve shared that there are three steps to quote in Chat. There are actually four steps to quote in Chat. I forgot to add “Click on select” that you can see in step 2 right now:
Yes, this is one of the things that makes the proposed feature more complicated, and I think one of the reasons we landed on the current solution first.
So definitely something we’d have to keep in mind.
It does lead me to also wonder whether some smaller tweaks to the existing solution are worth considering first, more focused on making the feature itself more discoverable and maybe take fewer steps.
But I also understand it’d be nice to have a UX that is more similar across chat and topics if we can pull it off.
Given the expectations set by topics, I’d personally prefer prioritizing a consistent, user-centred UX across both topics and chat, even if that introduces some additional implementation effort.
Would it be possible to get a rough estimate of the scope involved? That might make it easier for contributors outside the core team to assess whether they could help implement it.
I think the scope here is still far too open ended to estimate it or implement it at this point.
Some of the sources of complexity include:
  • in topics, we only let people quote from a single post at a time, while in chat, we need people to be able to select multiple messages to quote
  • in chat, on mobile, there isn’t any way currently to select part of a message, and long press brings up a menu
There are important details of the interaction design to figure out with regards to the above. We could attempt to do that first, through more discussion here or in a related topic. Or we could assume that has to be done during the implementation, in which case, I think we have to accept that we’ll be discovering scope and making design decisions along the way.
This is probably not an easy one for an outside contributor to land, especially not in one step.
