Install this theme component
Features
This theme component removes dashes from tag names wherever they’re displayed in the UI.
As Discourse replaces spaces in tag names with dashes, this theme component is useful for visually changing back dash → space in the display.
Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
Check document Perform check on document:
14 לייקים
JammyDodger
נושא זה פוצל ב־
22 ביוני, 2024, 12:53pm
9
Thank for your component,
Remove Dash from Tags side bar is OK, How about title Tag?
%{filter} %{tag} %{category}
Thank you for this. I could never understand the dashes there
The current theme component still misses many positions where the hyphen of the Tag Name cannot be removed, especially the website title to be friendly to Google. Can you update it?
לייק 1
MarkoK
(Marko)
1 באפריל, 2025, 8:35am
21
When enabling this theme component it also removes Tag icons from tags. So a bit conflict with this component: Tag Icons
Also as said before it misses removing those pesky dashes in few places.
לייק 1
eisammy
(Sammy)
7 באפריל, 2025, 10:39pm
22
This script replace this component for awhile
function replaceTextNodes(node) {
node.childNodes.forEach(child => {
if (child.nodeType === Node.TEXT_NODE) {
child.textContent = child.textContent
.replace(/-E-/gi, ' & ')
.replace(/-/g, ' ');
} else {
replaceTextNodes(child);
api.onPageChange(() => {
document.querySelectorAll('.discourse-tag.box').forEach(tag => {
replaceTextNodes(tag);
document.querySelectorAll('#sidebar-section-content-tags .sidebar-section-link-content-text').forEach(tag => {
לייק 1
