Streepjes verwijderen uit tag-namen
:discourse2: Summary Remove dashes (-) from tag names in the Topic List and on the Topic page
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository https://github.com/discourse/discourse-remove-dashes-from-tag-names
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
This theme component removes dashes from tag names wherever they’re displayed in the UI.
As Discourse replaces spaces in tag names with dashes, this theme component is useful for visually changing back dash → space in the display.
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
7 posts were split to a new topic: Dashes not removed from sidebar tags
Thank for your component,
Remove Dash from Tags side bar is OK, How about title Tag?
%{filter} %{tag} %{category}
Thank you for this. I could never understand the dashes there :smiley:
The current theme component still misses many positions where the hyphen of the Tag Name cannot be removed, especially the website title to be friendly to Google. Can you update it?
When enabling this theme component it also removes Tag icons from tags. So a bit conflict with this component: Tag Icons
Also as said before it misses removing those pesky dashes in few places.
This script replace this component for awhile
function replaceTextNodes(node) {
    node.childNodes.forEach(child => {
      if (child.nodeType === Node.TEXT_NODE) {
        child.textContent = child.textContent
          .replace(/-E-/gi, ' & ')
          .replace(/-/g, ' ');
      } else {
        replaceTextNodes(child);
  api.onPageChange(() => {
    document.querySelectorAll('.discourse-tag.box').forEach(tag => {
      replaceTextNodes(tag);
    document.querySelectorAll('#sidebar-section-content-tags .sidebar-section-link-content-text').forEach(tag => {
Wanted to come and make a note of this as well, with a request to bring this component up to date for interoperability. Sammy’s script works well enough that it could be PRed and optimized for inclusion.
