Discourse component over de volledige breedte
:information_source: Summary Make Discourse occupy the full browser width
:eyeglasses: Preview preview
:hammer_and_wrench: Repository Full-width component
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
:warning: This is still an experimental component, which overrides widgets, will most likely break with header refactors, and will not play well with other header components.
We’ll do our best to maintain this component and to minimise breaking changes, but we can’t guarantee these will never occur. A fix will most likely come, but you may have to wait a bit longer.
Example:
This component is currently also be used in the Fully and the “Default (full width)” theme here on Meta.
On very wide screens this might be less suitable.
It would be cool if this component interacted with the right sidebar component and carried it as far to the right as possible for symmetry.
I just updated to the latest version, and now I’m noticing an error on my screen
Discourse version: 3.3.0.beta1
If you upgrade Discourse, that should fix your problem.
Three days ago, the component got an update that relies on a recent addition in Discourse core.
You were right
Me too,
I use Fully Theme and this Theme Componet, How can we expand Table Inserted Full Topic-page?
Thank you!
You can try overwriting the CSS variables.
Create a theme component and attach it to Fully.
In the Color Definitions, add and adjust the variables:
:root {
    --topic-body-width: 100% !important; // 690px
    --d-max-width: 100% !important;  // 1110px;
Success.Thank you so much :slight_smile:
Hopefully it will be compatible with this theme
A post was split to a new topic: Topic titles and excerpts appear in different font sizes
Some category names are long and do not display fully in the sidebar.
How can we increase the width of the sidebar to match the length of the category name?
Thank you so much!
Hi,
  1. Is this component still experimental or fine to deploy in production environments ?
  2. Is this component officially supported ?
Thanks!
it’s officially supported in that we’ll look at bugs that are reported, but it’s still experimental in the sense that it’s not something we expect to work well with all themes and theme components
Given the announcement over here, I wanted to point out some discrepancies in experience when using the Full Width component and the header search feature.
Safe Mode:
Safe Mode + Full Width component:
I assume at least the same experience should be the case, if not simply collapsing the header search to an icon for very low page widths (like on the mobile view).
We just recently merged a fix to ensure the header search bar collapses to the icon on small screen widths. Once you’ve updated Discourse, could you please take a look and let us know if that’s looking better?
