הזזת הפוקוס בעת חיפוש בספריית המשתמשים
If you type not fast enough in the search field of the user directory, the focus shifts to :heart: Received, leading to the activation of keyboard shortcuts if you don’t notice.
Short screencast of the focus shift:
And one where, by trying to add a “u”, the keyboard shortcut is triggered:
5 לייקים
Copied from here:
When I’m searching for a group name here and start to type, the search is filtered according to all the symbols I already typed after each symbol. I can wait as long as I want between the symbols.
However, when I search for a username here, after each symbol, I must type the next symbol after not more than ~0.4Sec or else, the results are filtered, and the cursor is no longer inside the search window, so I cannot continue typing (unless I put the cursor back inside the search window again and again after each symbol).
I reckon 0,2 sec is closer :winking_face_with_tongue: It has been such as long I’ve used Discourse. That’s why I think it is un-usable and I as an admin go to admin side if I need to operate with users.
2 לייקים
Just merged a fix which should prevent this behaviour: https://github.com/discourse/discourse/pull/29209
5 לייקים
Works great. Thanks.
But you broke the table headings for plugins.
לייק 1
Yikes, thanks a lot.
8 לייקים
I also have the impression that your changes also broke the User Card Directory component. At least I can no longer click on “:heart: received” or “:heart: given” in the cards view to change the order.
3 לייקים
Appreciate your callout here @moin!
It also turns out there was another component affected
I’ll close this topic next week in case there are more that pops up but I did a quick scan and it looks like we’re fine.
5 לייקים
This topic was automatically closed after 7 days. New replies are no longer allowed.
