פתיחת מקלדת בתיבת קלט מודאלית גורמת לגלישה חזרה לראש הדף במובייל
סיכום מבוסס בינה מלאכותית
Users reported a bug on mobile where opening the keyboard in a modal causes the page to jump to the top, disrupting the reading position. The issue was observed on Android 10 with Chrome, affecting various input fields, including search and form templates, and was also noted in the AI explain and flag modals. Don and Heliosurge provided examples and screenshots, with Moin clarifying that the issue differs from similar ones where the keyboard covers content. lindsey acknowledged the reports and confirmed the fix has been implemented, resolving the scroll issue. NateDhaliwal and nwnuyhs corroborated the problem, and lindsey invited further feedback if the issue persists.
Hello :wave:
When I open the keyboard on a modal input this will jumps the page to the top.
Android 10; CLT-L29 Build/HUAWEICLT-L29
Chrome 123.0.6312.80
Thank you :slightly_smiling_face:
3 לייקים
I have similar issue in various spots like here if I shrink the keyboard to use search
With keyboard closed
With keyboard open search input is blind
keyboard will also block/cover up the form template editor and a few other spots.
There is another topic about that Android keyboard overlaps/interferes text edit fields
לייק 1
Yeah I see we have a couple topics on this issue. With oldest I think from March 22?
Don’s theme component doesn’t fix it in the form-templates
I think the issue in this topic is not about the keyboard covering something, but about you being taken to the top of a topic (list) when you use a modal.
They look like they might be at least in part related in some way maybe?
At least going by the video.
I also noticed the jump to the top after using AI explain. It’s quite annoying because you lose your reading position.
לייק 1
Yes,I have same problem
There is the same problem when typing in the flag modal, for Something Else or Illegal.
2 לייקים
Thanks for reporting this, everyone — I’ve asked our team to fix this up!
3 לייקים
Hey folks :blob_wave: We’ve fixed this issue so you shouldn’t get scrolled to the top anymore after opening the keyboard within a modal. Please let us know if you continue to encounter this problem!
7 לייקים
