As the title already says: it seems that the strings for the titles on graphs in the community health dashboard are not localized:
When switching to the reports tab, the localized titles are shown:
However, when looking at an individual report/graph, again the English title is used and both day and count in the table headings are also not localized:
tvavrda
(Tomas Vavrda)
31 december 2024 om 11:41
This is still the case. Also noted here: Report locale copies do not update with user locale .
Can it be fixed?
sam
(Sam Saffron)
1 januari 2025 om 22:53
3
I have flagged this with the team, no timeline though on when we can resolve this.
Would you like to try out making PR to improve this?
tvavrda
(Tomas Vavrda)
1 januari 2025 om 23:13
5
It might be challenging for me
And as we speak the notification mail I’ve got has not the In Reply To heading localized, although the e-mail otherwise seems to be translated.
martin
(Martin Brennan)
2 januari 2025 om 02:22
6
This should fix the report issue:
main ← fix/report-i18n
merged 03:05AM - 02 Jan 25 UTC
Our bulk report endpoint uses `hijack`, which does not
use the current user's l… ocale via the `with_resolved_locale`
method in `ApplicationController`. This is happening because
we are doing `around_action` to set the locale, then calling
the code in the block inside the action directly when we use
`hijack`.
We can fix this by capturing `I18n.locale` when starting the
hijack then using `I18n.with_locale` when evaluating the
block inside `hijack`, this way the translations will always
use the correct locale based on the current user.
c.f. https://meta.discourse.org/t/titles-on-graphs-in-community-health-dashboard-are-not-localized/302776/5
For the “In Reply To” issue, it looks like our Czech translations are a bit lacking, our German server.de.yml file has user_notifications.in_reply_to but server.cs.yml does not. Translations fall back to English when keys are missing.
tvavrda
(Tomas Vavrda)
2 januari 2025 om 08:49
7
I am sorry, you are right. I confused myself. I translated the phrase just 4 days ago and yesterday it looked like it should have worked. The translations have not been committed yet though.
Thanks for the fix, it works!!
tvavrda
(Tomas Vavrda)
2 januari 2025 om 14:04
8
I noticed the tooltips are not translated.
Found the piece of code as well:
return i18n("admin.dashboard.reports.trend_title", {
percent,
prev,
current,
changeTitle(valAtT1, valAtT2, prevPeriodString) {
const change = this.percentChangeString(valAtT1, valAtT2);
let title = "";
if (change) {
title += `${change} change. `;
title += `Was ${number(valAtT1)} ${prevPeriodString}.`;
return title;
@discourseComputed("yesterdayCount")
yesterdayCountTitle(yesterdayCount) {
return this.changeTitle(this.valueAt(2), yesterdayCount, "two days ago");
I am just a c# guy, so I am not able to make PR’s.
martin
(Martin Brennan)
3 januari 2025 om 00:09
9
Come on, C# is close enough to Javascript! Thanks for finding that, I will make a PR to fix the JS to use I18n.
martin
(Martin Brennan)
3 januari 2025 om 01:04
10
This will fix the other issue, though you won’t see any practical change until our next round of translations:
main ← fix/report-percent-tooltip
merged 01:20AM - 03 Jan 25 UTC
Use i18n in the JS code instead of concatenating English
strings.
c.f. https… ://meta.discourse.org/t/titles-on-graphs-in-community-health-dashboard-are-not-localized/302776/8?u=martin
tvavrda
(Tomas Vavrda)
3 januari 2025 om 10:08
11
It’s not all. I commented on the PR although it was merged, not sure if you can spot it.
There are more translations below (“two weeks ago” and “in the previous 30 day period”).
martin
(Martin Brennan)
6 januari 2025 om 04:48
12
This next PR should fix those issues, as well as the comments Gerhard added!
main ← ux/more-admin-dash-translations
merged 11:49PM - 06 Jan 25 UTC
Followup 8d5c4ecc3398611764a4459c0e92f0fb90edd90f
Implement review suggestion… s from https://github.com/discourse/discourse/pull/30541
after merge, and also fix other hardcoded strings on this
dashboard.
tvavrda
(Tomas Vavrda)
10 januari 2025 om 16:09
13
There seem to be other topics referring to the same problem. I don’t want to bump them all. What is the right thing to do? Just let them be or should they be somehow updated or closed?
Reports, along with their locale strings, are being cached in the server’s locale, such that users with a differing locale will see an incorrect locale on some reports - should Discourse also pass a localization string in reports so that reports are properly localized?
EG, this is a screenshot of a default EN site, with a sr user:
[Screen Shot 2019-12-13 at 11.37.29 AM]
Hello community ,
I noticed that the strings in the admin/moderator dashboard are not being translated. Tried multiple languages and it keeps those strings in English.
[image]
I wanted to add translations to those strings in Crowdin but those strings already have translations. So I ran a search query and found out this topic:
It looks like there was a PR but was not merged at the end.
Was there any progress with that issue?
Thank you
I have found some strings that are translated in Transifex, but doesn’t appear translated in production. They are in Admin>Dashboard: Signups, Topics, Posts, Daily Engaged Users, New Contributors, Top Referred Topics, Trending Search Terms, Users per Type… (with its corresponding tooltips).
This issue is common to all languages. I have checked different locales (French, German, Catalan…), and the strings always appear untranslated.
First of all: thanks a lot! I didn’t have enough time to comment in the meantime, but I see that localization is applied much more widely in the dashboard now.
On small thing I still noticed: the back link to the report overview page does not seem to be localized.
And recommendations regarding site settings appear in English, too:
Moin
18 januari 2025 om 16:25
15
They are. You can see that when you enable “verbose localization ” because they have a number.
Those are just new strings, both were translated to German 4 days ago, but translations are only merged once a week. So brand new strings, that were added after translations were merged (or slightly before and no one had time to translate them in time) fall back to English. The translation will be added the next time translations are merged (usually Tuesday ) and you will see them after updating.
