Discourse Surveys
The Discourse Surveys plugin enables the creation of interactive surveys within forum posts using simple Markdown syntax. Supported field types include radio buttons, checkboxes, dropdowns, text areas, number inputs, star ratings, and thumbs up/down. The plugin respects topic permissions, ensures mobile responsiveness, and prevents duplicate submissions from the same user. While a basic example query is provided for Data Explorer, the plugin initially lacked a native backend UI for viewing results, a limitation that frustrated users like Jagster and tobias eigen who preferred not to rely on manual SQL or see aggregated results similar to standard polls.
User nathank contributed a significant improvement by sharing a prompt to generate optimized, pivot-table-style SQL queries for easier data analysis, which was praised by merefield. Additionally, initial confusion regarding survey rendering in the composer was clarified by techAPJ, who noted that previews often show placeholders but render correctly once the topic is posted.
Recent development efforts, led by singi2016cn, have addressed key community requests. These include a Pull Request adding support for anonymous survey submissions via a new surveys_allow_anonymous_submissions site setting, allowing guests to respond using a localStorage token. Other enhancements include visual indicators for required fields (singi2016cn) and the ability for users to edit their own survey responses after submission (singi2016cn). The community continues to express interest in further improvements, such as native result visualization, with users like satonotdead hoping for these features to be shipped to enable broader testing.
:discourse2: Summary Discourse Surveys plugin allows you to create surveys directly within your Discourse forum posts using simple Markdown syntax.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-surveys
:open_book: Install Guide How to install plugins in Discourse
The Discourse Surveys Plugin allows you to create surveys directly within your Discourse forum posts using simple Markdown syntax. The plugin currently supports a variety of question types such as radio buttons, checkboxes, dropdowns, number inputs, text areas, star ratings, and thumbs up/down ratings.
Features
  • 7 Different Field Types: Radio buttons, checkboxes, dropdowns, text areas, number selection, star ratings, and thumbs up/down
  • Required/Optional Fields: Mark fields as required to ensure completion
  • Emoji Support: Use emojis in your survey options
  • Markdown Support: Rich text formatting in questions and options
  • User Authentication: Automatic login prompts for anonymous users
  • Response Tracking: Prevents duplicate submissions from the same user
  • Permission Aware: Respects topic and category permissions
  • Mobile Responsive: Works seamlessly on all devices
Usage
Basic Survey Structure
All surveys must be wrapped in [survey] tags:
[survey name="my-survey" title="Customer Feedback Survey"]
<!-- Survey fields go here -->
[/survey]
Survey Attributes
  • name: Unique identifier for the survey (defaults to “survey”)
  • title: Optional title displayed at the top of the survey
  • public: Set visibility (future feature)
  • status: Survey status (future feature)
Field Types
1. Radio Buttons (Single Choice)
[radio question="What is your favorite color?"]
- Red
- Blue
- Green
- Yellow
[/radio]
2. Checkboxes (Multiple Choice)
[checkbox question="Which features do you use? (Select all that apply)"]
- Email notifications
- Mobile app
- Desktop notifications
- API access
[/checkbox]
3. Dropdown Selection
[dropdown question="What is your age group?"]
- Under 18
- 18-24
- 25-34
- 35-44
- 45-54
- 55+
[/dropdown]
4. Text Area (Long Form Text)
[textarea question="Please provide detailed feedback:" required="false"]
[/textarea]
5. Number Selection
[number question="Rate this feature from 1-10:" min="1" max="10"]
[/number]
6. Star Rating
[star question="How would you rate your overall experience?"]
[/star]
7. Thumbs Up/Down
[thumbs question="Would you recommend this to others?"]
[/thumbs]
Field Attributes
All field types support these attributes:
  • question: The question text (required)
  • required: Whether the field must be filled (true/false, defaults to true)
  • min: Minimum value for number fields
  • max: Maximum value for number fields
Complete Example
Basic Survey Markdown
Here is a basic example of survey Markdown including all available fields:
[survey name="awesome-survey-thumbs" title="Awesome Survey"]
[radio question="Choose any one option:"]
- cat
- dog
[/radio]
[checkbox question="Choose multiple options:"]
- red
- blue
- green
[/checkbox]
[dropdown question="Gender:"]
- Male
- Female
[/dropdown]
[number question="Rate this survey from 1 to 10:"]
[/number]
[textarea question="What is your feedback about xyz?" required="false"]
[/textarea]
[star question="How would you rate overall experience?"]
[/star]
[thumbs question="Were you satisfied with our services?"]
[/thumbs]
[/survey]
Survey Rendering
Below is an example of how the above Markdown renders in Discourse:
Advanced Usage
Using Emojis in Options
[radio question="Choose your favorite animal:"]
- 🐈 Cat
- 🐶 Dog
- 🐦 Bird
- 🐠 Fish
[/radio]
Markdown Formatting in Questions
[radio question="Which **programming language** do you prefer?"]
- JavaScript
- Python
- Ruby
- Go
[/radio]
[checkbox question="Select your *favorite* features:"]
- Speed
- Security
- Ease of use
[/checkbox]
[textarea question="Please read our [guidelines](https://example.com) and provide feedback:"]
[/textarea]
Supported formatting:
  • Bold: **text**
  • Italic: *text*
  • Strikethrough: ~~text~~
  • Inline code: `code`
  • Links: [text](url)
Mixed Required and Optional Fields
[survey name="mixed-survey"]
[radio question="What is your role?" required="true"]
- Developer
- Designer
- Manager
- Other
[/radio]
[textarea question="Any additional thoughts?" required="false"]
[/textarea]
[/survey]
Survey Results
Currently, this plugin does not have any backend UX to view the survey results directly. Instead, you can rely on Data Explorer queries to fetch and analyze survey responses. Here is an example query:
-- [params]
-- text :survey_name = survey
SELECT
  s.id,
  s.name,
  s.post_id,
  sf.question,
  COALESCE(sr.value, sfo.html) AS value,
  sr.user_id,
  sr.created_at AS responded_at
FROM
  surveys s
  JOIN survey_fields sf ON sf.survey_id = s.id
  JOIN survey_responses sr ON sr.survey_field_id = sf.id
  LEFT JOIN survey_field_options sfo ON sfo.id = sr.survey_field_option_id
WHERE
  s.name = :survey_name
ORDER BY
  s.id DESC
Support exporting admin pages from the backend
visit /admin/plugins/discourse-surveys/export
Permissions and Security
  • Login Required: Anonymous users must log in before submitting responses
  • One Response Per User: Each user can only submit one response per survey
  • Topic Permissions: Users must have read access to the topic to view surveys
  • Posting Permissions: Users must have posting permissions in the topic to submit responses
  • Archived Topics: Surveys in archived topics cannot accept new responses
  • Deleted Posts: Surveys in deleted posts are no longer accessible
Limitations
  • Only one survey is allowed per post
  • Survey structure cannot be modified after receiving responses
  • All survey field questions must be unique within a single survey
  • Survey field questions cannot be blank
Technical Details
Database Schema
The plugin creates four main database tables:
  • surveys: Main survey records
  • survey_fields: Individual fields within surveys
  • survey_field_options: Options for choice-based fields
  • survey_responses: User responses to survey fields
Styling
The plugin includes responsive CSS that adapts to your theme. Custom styling can be added by targeting these CSS classes:
  • .survey - Main survey container
  • .survey-field - Individual field wrapper
  • .field-[type] - Specific field type containers
  • .submit-response - Submit button
So users can’t see results (unless they have rights to use query) and this is totally for admins/background staff?
Yes, that is correct.
It doesn’t feel very practical :cry:
Need option to publish survey results. Otherwise better to use multiple polls.
Hello
The sample Markdown renders in a new Topic as per below. My Discourse is updated to the latest version.
What could the the problem?
Regards
Hey @ppcole,
The above is what is shown in composer preview when you’re creating the survey. Once you create the topic it will render properly as expected.
Thanks Arpit. It worked. Looking forward to enhancements
May I know if you folks are working on this but not with actual priority?
It would be great to have this continue to be developed - it has masses of potential.
I found that the SQL above did pull out the results, but it wasn’t in an easy to work with format; basically it would require a tonne of transformation at the spreadsheet level to enable useful analysis.
However, with a bit of Gen AI help, I was able to produce a very sweet Data Explorer query. Due to some limitations of Data Explorer, it isn’t possible to make it dynamic enough to cope with a variety of surveys; basically you need a bespoke query per survey.
Fortunately, Gen AI can make that pretty straight forward. Here is a sample prompt that will probably work in most Gen AI services (if you don’t have the AI plugin active) - just plugin in your survey markdown and you should be away:
Gen AI Prompt to Produce Tailored SQL Query for a Specific Survey
I have a survey defined in markdown format, and I need a SQL query to extract the survey results from a Discourse database using the Data Explorer Plugin. The survey includes various types of questions such as radio, dropdown, star, checkbox, textarea, thumbs, and number. I want the query to output results with each user having a single row and each question having its own column. For checkbox questions, multiple responses should be concatenated into a single string.
Here is the survey markdown:
Paste your survey markdown here
Here is the original query used to obtain survey results:
-- [params]
SELECT s.id, s.name, s.post_id, sf.question, COALESCE(sr.value, sfo.html) AS value, sr.user_id, sr.created_at as responded_at
FROM surveys s
WHERE s.name = :survey_name
ORDER BY s.id DESC
Please generate a SQL query that:
  • Hardcodes the survey name.
  • Uses conditional aggregation to pivot the data, with each question as a column.
  • Utilizes STRING_AGG for checkbox questions to handle multiple responses.
  • Ensures the output is grouped by user_id and ordered by user_id.
  • Is formatted for readability and includes comments explaining the logic where necessary.
Additional Guidance for Data Explorer Plugin:
  • The query should be compatible with the Discourse Data Explorer Plugin, which means it should not end with a semicolon.
  • Use column names like user_id to leverage automatic linking features within the Data Explorer.
  • Avoid using dynamic SQL, as the plugin does not support it.
  • Ensure the query is efficient and optimized for performance, as it may be run on large datasets.
This is an excellent little plugin that is surprisingly feature rich. Thanks for making it.
@nathank great job on guide to quickly building results query. That makes the whole thing even more useful :rocket: (and should be moved to the OP)
I installed this on my self-hosted site to take it for a spin, and it’s quite nice indeed!
I realize this is anathema to discourse, but it would be helpful if it were possible to create surveys that can be completed anonymously, without logging in. Or at least to anonymize the results so they are not associated with specific users.
And of course yes the ability to look at the results like you can with polls without having to resort to data explorer would be fantastic.
Yes I faced the same issue. Hopefully there is a solution.
Any updates to the survey feature?
Out of interest, what update were you hoping for?
I think this can be shipped now to allow us to get into it and test how it works on our communities in a simple way :slight_smile:
I wish there was a setting to determine whether users can submit survey forms anonymously
FEATURE: Allow anonymous survey submissions gated by `surveys_allow_anonymous_submissions` by singi2016cn · Pull Request #109 · discourse/discourse-surveys
Previously, only logged-in users could submit survey responses, since SurveyController enforced ensure_logged_in and survey_responses.user_id was NOT NULL.
This change adds the surveys_allow_anonymous_submissions site setting so signed-out visitors can respond using a per-browser localStorage token for de-duplication, and includes anonymous respondents in admin response counts and CSV exports.
Commits (17 files, +651/−74)
  • Feature: Site setting + migration (user_id nullable, anon_token, partial unique index) + backend anonymous path + IP rate limiting + frontend login block removal and token management
  • Fixes: CSV export missing anonymous replies, admin panel counts omitting them, missing survey.no_survey_with_this_name
  • i18n: 26 keys fully aligned for en + zh_CN
  • Docs: README fixed 5 contradictory descriptions, added Anonymous Responses section
  • Tests: 125 cases passing (lib 26 / requests 38 / system 61)
feat: add required field indicator and update styles and internationalization support
UX: Show a required indicator on mandatory survey fields by singi2016cn · Pull Request #108 · discourse/discourse-surveys
A red asterisk has been added to the right of required fields to indicate to users that the field is mandatory.
After submitting, users can view their submitted information and are allowed to modify it again.
