Kan geen nieuwe berichten maken met categorieën met geïnstalleerde sjablonen
Recently I installed the experimental form templates
feature as reported, but after creating a form for the category, the “create topic” button did not work.
Do I need to install anything else to enable this feature?
No as long as you enable the feature in settings, create a template and assign it to a category it’ll work.
Are there any errors in logs and does it occur in safe mode?
Thank you, after trying to turn off the plugins one by one, the form template feature is working, they are affected by the “Perspective Api” plugin, this is an offical plugin, I hope the discourse team can check and correct it.
Yes i second that. Its not working with Discourse Google Perspective API
@hoangphuctran93 / @David_Ghost could you share the following so that I can better diagnose this issue?
  • the form template(s) used
  • the perspective settings you have changed
If you can manage to reproduce the issue with a minimum of changes, that would be greatly appreciated as well :+1:
Thanks
Nevermind. I’m able to reproduce. Will fix :mag:
I have a fix in the work
https://github.com/discourse/discourse-perspective-api/pull/93
PR is now merged.
Thanks, I will reinstall and get back to you with my experience.
This topic was automatically closed after 3 days. New replies are no longer allowed.
