유저 카드 디렉터리: 모바일에서 메시지 버튼이 표시되지 않아야 함
Edit by Tobias to clarify the problem:
When the User Card Directory theme component is enabled, the message button on the usercard is shown in the user directory on mobile but is not clickable. The button is not shown on desktop and should not be shown on mobile either.
4개의 좋아요
Hello everyone, I installed and found issue or bug when clicking the Message Button in the User Card Directory. Instead of loading the Message Composer the button disappears and the user card remains. I checked on the User Card Directory Demo on Discourse and same issue is present. Chat button works normally. It would be good if they did not appear on the active user who cannot message or chat with himself :slight_smile:
1개의 좋아요
I already started a topic about the buttons being visible in the directory on mobile: User Card Directory: message button should not show on mobile
By the way: you can message yourself. It’s helpful for drafts and notes.
2개의 좋아요
I tested this and am also able to see a problem similar to that reported by @Brianc:
  1. when user card direcory enabled
  2. visiting user directory
  3. select Message button on a user card
  4. not taken to the new message composer, the avatar and username disappear from the card
@moin you haven’t provided enough information for me to understand what you are reporting in User Card Directory: message button should not show on mobile. Are you talking about something else?
1개의 좋아요
I think the message button shouldn’t be visible at all.
In desktop view you see this: open this in a new tab for desktop view
There is no message or chat button. It’s hidden by the component’s css:
But in mobile view, those are shown open this in a new tab for mobile view
The css is overwritten
So I think the problem is not that they do not work as expected, but that they aren’t hidden on mobile. You would not be able to click those buttons if they were hidden as expected.
1개의 좋아요
I assumed the chat/message buttons were intended to be there. If there are adjustments/enhancements made for this theme component perhaps an option to show or hide could be added. I like being able to message/chat with other users when looking through directory personally.
1개의 좋아요
I moved all the related posts into here.
Funny, when I was testing the buttons were showing on desktop too but they are no longer showing. I guess I had to do a hard refresh in my web browser.
I’m in favor of not showing the buttons at all - it clutters the view and if you want to send a message or chat you can click on a card to see the full user card with buttons.
1개의 좋아요
Sounds good. Thanks for reviewing. I popped this into the mobile css for the theme to remove.
.usercard-controls {
display: none!important;
