사용자 프로필에 숨겨진 그룹 멤버십이 표시됨
I noticed that groups where I’m not allowed to see the members still appear on the user profile.
For example, as long as you don’t join @new-new-testers, you cannot see the members of that group:
But when you look at a user profile of a member, you can still see that they are a member of the group:
However, when you click the 3 dots to see all group memberships, it is hidden.
This also affects groups where you are not allowed to see the members even if you are a member yourself.
3개의 좋아요
Hello, @Moin! :blob_wave:
Thanks for reporting this. We initially treated this as a bug, but it seems that this quirk is documented when setting up a group:
If the group itself is set to not be visible, it will not show up in the flair of its members.
I’m bringing this question back to the product team to see if we want to improve this somehow, as it is currently not possible to have a visible group with hidden members without leaking the membership through flair.
Will reply here when we have an update. :pray:
I had understood it to mean the group-flair. So, for example, if the members of the team group were not public, I could still see the flair.
For me, this is different from the list in the profile. Or is that also a “flair”?
1개의 좋아요
I think you are right in that this might not officially be considered “flair”. :thinking: The option we are discussing now is adding an additional checkbox for deciding whether the membership should show on users’ profiles or not, but even if we don’t we should clarify this notice in the UI. :+1:
Depending on how you decide, it would make sense to change the view that you get when you click on ‘…’. Then, groups whose members you are not allowed to see will not be displayed.
It’s confusing that “new-new” does not appear then.
What is the idea of hiding the members if you can still find out in their profiles?
1개의 좋아요
I’m back to thinking this is just a straight up bug. Will start looking into it tomorrow. :slightly_smiling_face:
2개의 좋아요
@Moin Found the exact point when this regression happened. Working on a fix now. :pray:
4개의 좋아요
Thanks for fixing!
https://github.com/discourse/discourse/pull/29799
As long as I am not a member of @new-new-testers:
:heavy_check_mark: group not shown
After joining @new-new-testers, so I am allowed to see the members of the group:
:heavy_check_mark: group shown
2개의 좋아요
I think it is working correctly:
1개의 좋아요
I didn’t want to express anything else. It was just a test to see if the group is actually still displayed when it should be. It could also have disappeared because the user is no longer a member.
4개의 좋아요
Thanks for the confirmation, @Moin! Let me know should you stumble on any more edge cases. :pray:
2개의 좋아요
