לא ניתן להוסיף פורום חדש ל-DiscourseHub
סיכום מבוסס בינה מלאכותית
Users reported that the DiscourseHub mobile app (iOS/Android) no longer allows adding new forums directly from the Home tab — the + button previously used for this is missing. merefield and Jagster confirmed the feature still exists but is now buried under the Discover tab, requiring users to search for or manually enter a forum URL. While functional, this change is unintuitive, especially for existing users accustomed to the old workflow merefield. Jagster noted additional UX issues: confusing search behavior (e.g., laji.fi fails, foorumi.laji.fi works), misleading text (“give address of your site”), and Discover’s branding as a “showcase,” not a setup tool. Moin pointed out a small button on Home that leads to Discover, but acknowledged it’s not prominent. pmusaraj acknowledged the feedback and announced a fix: restoring the + icon on Home for adding forums by URL. A beta build was released via TestFlight pmusaraj, pending Apple’s review, after which it will roll out to all users pmusaraj. The issue was tagged ux and closed early pending the update.
iPhone/iPad and DiscourseHub: I can’t add new forum unless it is on Discover. So I think there is one + sign missing.
2 לייקים
Same appears to be the case on Android.
Was this a deliberate feature change? Hope not!
Ah. I think this might have been a deliberate change.
I could be wrong but I believe you can add an arbitrary Discourse and it doesn’t have to be in the discover list.
You do so now on the new screen:
So the Discover tab now serves both purposes.
I’d argue this is not perfectly intuitive, especially for existing users.
לייק 1
Try here
This report concerns the app not the website.
2 לייקים
Contribute > UX or Support would be better?
לייק 1
Contribute > UX imho.
Looks like the feature is there and working.
They have simply removed the feature from the first tab.
In some ways the new solution is better but could perhaps have been more obvious? :thinking:
3 לייקים
There may be other technical thing too that could work better — seaching.
I couldn’t find anything when searched laji.fi but foorumi.laji.fi worked (of course, it is an exact form).
If it would be as… fuzzy (sorry, can’t remember term of searching part of words) than what forums use finding relevant hits could be easier.
לייק 1
I see a button to add the site when I enter the url:
Yeah, on Discover side when that forum is found. So it is for them who knows how the Hub works. For new comers it is not do obvious that adding a forum is in different location where connected forums are. So Home isn’t the place where head, it is Discover instead (plus UI of the Hub is in English, of course)
For new comers there is a button at “home” which takes them to discover to add communities. (By the way, that is also localized)
לייק 1
Yes hence my prior Post.
But it’s not obvious like the plus button was.
I think this change mostly impacts existing users who are used to a different workflow.
Now I know. :sweat_smile:
2 לייקים
Well, I didn’t find way to add new forum. Mostly because
  • it wasn’t there where it was last time I used
  • Discover is, and has been avertized as such, a showcase room or window
  • the search (only translated text) tells give adress of your site
  • search didn’t work as expected
Sure, I’m not a pro, but not pure end user either (ok, sometimes I ask really stupid questions :rofl:) and if adding new forum wasn’t obvious
  • it wasn’t obvious for me [1]
  • I claim it will not be obvious for new user when trying add second forum after time period X
  1. a classical support situation what I’m teaching almost everyday: if an user says it didn’t work then it really didn’t work, no matter if wrong button was clicked; different thing than a customer is always right, because they are mostly wrong ↩︎
4 לייקים
Yeah, these are all good points, thanks folks, I am working on an update of the app that restores the + icon and keeps it working for the function of adding a site by URL to DiscourseHub. Here’s a very quick demo:
Beta build should be ready this week.
3 לייקים
Beta build is ready, please use this link to try it out: https://testflight.apple.com/join/mzqp6Bk3
2 לייקים
The beta build of the app is now awaiting Apple’s review, once approved, this will roll out. Closing this topic early.
2 לייקים
