Discourse Doc Categories
:discourse2: Summary Discourse Doc Categories provides the ability for particular categories to be set aside for documentation, enabling additional features for them.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-doc-categories
:open_book: Install Guide How to install plugins in Discourse
:warning: Note that this plugin is in active development and not yet fully complete.
Features
The Discourse Doc Categories plugin that allows you to host structured documentation on an existing Discourse forum. It works by setting aside specific categories for documentation, and providing features to make finding specific documentation topics easier.
You can see it in action at in the Documentation category.
When marking a category as a location for documentation, the following features are enabled for that category:
  • A specified topic to be used as an index for all the documentation topics in the category
  • A new sidebar for navigating between different topics in the category, including built-in filtering and search functions
  • New reports to help you maintain the integrity of the index topics
In addition, the plugin handles redirects for site that are migrating from the retired Docs plugin. Documentation links from that plugin will redirect to their existing topic URLs, and there is a setting for redirecting your previous documentation homepage to your main documentation category.
Configuration
Configuration settings are available at example.discourse.com/admin/site_settings/category/doc_categories. Here you will find the following settings:
  • doc categories enabled: Select to enable the Doc Categories plugin.
  • doc categories docs legacy enabled: Select this if you have migrated from the deprecate Docs plugin.
  • doc categories homepage: With the previous setting enabled, the landing page from the deprecated Docs plugin will redirect to this URL.
To specify which categories will be used for documentation, assign them an index topic. To do this, open the category’s settings by clicking the :wrench: icon on the category page. From there, click the ‘Settings’ link and scroll down to the ‘Documentation mode’ section. Use the ‘Index topic’ field to specify the topic that will be used for the index of the category.
Index topics
The index topics for a documentation category serve two purposes:
  1. They are a central list of all the topics included in the category
  2. The sidebar included with this plugin is populated by the index topic content
Formatting index topics
Index topics can include any content you like. In order for the sidebar to function correctly, they need to include a bulleted list (or mulitiple bulleted lists) of documentation topics. These can simply be the topic URLs in a list, in which case the sidebar will show the full title for each documentation topic.
Having the full title in the sidebar might not be practical if your titles are longer than a few words, so to set shorter titles for a particular topic, precede the URL with a shortened title followed by a colon (:). All the text before the colon will be shown in the sidebar and it will link to the topic URL.
You can divide your index topic into sections and use multiple lists with headings (of any level) above each one - they will then be displayed in the sidebar in these sections.
Here’s an example of an index topic to get you started:
You can start with an optional brief description of the category.
## First section
* https://discourse.example.com/t/topic-title/12
* https://discourse.example.com/t/another-topic-title/34
* Short title: https://discourse.example.com/t/topic-with-a-long-title/56
* Another title: https://discourse.example.com/t/another-topic-with-a-long-title/78
## Second section
* Topic title: https://discourse.example.com/t/documentation-topic/98
* https://discourse.example.com/t/new-topic/76
That example will output a documentation sidebar that looks like this:
:eyes: See the Documentation > Site Management index topic for an example of a documentation category index in action: https://meta.discourse.org/t/site-management-index/308032
Maintaining index topics
While the index topics will not be automatically updated as content in the category is added, removed or edited, the plugin includes new reports that highlight where there are inconsistencies within the index topics.
  • Topics not indexed:
    example.discourse.com/admin/reports/doc_categories_missing_topics
    This report shows any topics in the documentation categories that have not been added to the index.
  • Extraneous items:
    example.discourse.com/admin/reports/doc_categories_extraneous_items
    This report shows items included in the index that look like they should not be there. The report will indicate the reason that the topic has been included in the report - for example, if it has been deleted or it is in a different category to the index topic in which it is included.
Additional info
Adding the string in:docs to a search term will search all categories that are marked for documentation (i.e. they have an index topic assigned).
The max number of items in the index is set by the Max oneboxes per post site setting, which defaults to 50. If you need more than 50 index items, increase the number in that setting.
Last checked by @hugh 2024-08-27T01:23:09Z
New documentation plugin in development
Discourse vs Skool
Discourse Docs
How to create a sidebar similar to meta documentation sidebar?
Using Discourse as Learning Platform
Sub-sections on the sidebar without sub-categories
I am very interested in the 'documentation' feature
A better way to manage indices for Doc Categories?
Create index topic
Using Discourse as an enterprise wiki library
How to arrange sub categories as list items under a category
Custom Platform
Custom topic ordering
Collections
Displaying "full topic" text on category page + access to subcategory from menu bar
Need Help on Category on left sidebar
Sidebar activation issues after recent Doc Categories update
Bulk Export of Raw Post Sources with Markup
Discourse Doc Categories is now available on Business
Discourse Docs
Published Pages for documentation?
Topics (with replies) bumped on title edit
Theme customize - sidebar content
Questions about subcategories displaying in wiki sidebar
Doc pages - Schema Article
Structuring an active support community migrating from Facebook
Use more often placeholder forms in documentation topics?
Is there a plugin that allows you to organize all the URLs of a category into one topic?
Sidebar spacing change?
What is the best way to Publish a book with chapters?
Click a category to open a subcategory page
How to add this header, colored categories, and sidebar categories?
Discourse Doc Categories links not rendering
This is quite nice… Was just looking into other self-hosted docs solutions (the forum structure can be a bit confusing sometimes for new readers).
Good luck to Discourse (vs. Gitbook & others :smiley:)
I would guess component discourse-doc-sidebar (did I remember the name right) isn’t needed anymore?
Yes - the component that was originally built for the new documentation sidebar has been moved to this plugin.
I guess this doesn’t work with tags anymore? :slight_smile:
I love the approach as is neatly integrating into the core discourse navigation instead of a brand new one as in the Docs plugin.
We will be happy to make the switch!
Just dropping this here, totally not a native feature request. Even though these might not be specifically applied for this plugin, I do think they are excellent features to have in any docs environment - as benefit, they could be great core additions too. :thinking:
Something like the footnote feature, but globally keyword triggered would be epic for such a feature.
If we have hover previews, which are shown on any internal link on your forum, you don’t even need this, Word/Link replacement can take care of this, and one simply has to hover on a this word and read the full post without opening it :smiley:
Features like this are very convenient (since no one likes to read docs, right?) and with the release of this plugin, in the middle of my journey of picking the best solution to host my docs, makes it a lot harder difficult for me :stuck_out_tongue: I was exploring moving my docs to Quartz with content managed in Obsidian.
Any chance, it will be compatible with 3.3 stable?
Yes, this is fully compatible with Discourse 3.3 :slight_smile:
No, it’s not:
/var/www/discourse/plugins/discourse-doc-categories/lib/doc_categories/initializers/invalidate_cache_on_enabled_setting_change.rb:8:in `apply': undefined method `on_enabled_change' for an instance of Plugin::Instance (NoMethodError)
** INCOMPATIBLE PLUGIN **
You are unable to start Discourse due to errors in the plugin at
See DEV: Add plugin API to perform actions when the plugin is turned on/o… · discourse/discourse@366dfec · GitHub
Emoji rendering in the titles & items in the sidebar would be awesome!
Hi, guys!
Sorry, this was my error.
I’ve made a mistake when Hugh asked me if the plugin was compatible and assumed the new APIs I introduced in core when I was developing it, did make the cut for 3.3 stable.
Unfortunately, this was not really the case and the first stable version the plugin will be compatible is 3.4.
Again, sorry for the confusion.
How about group tag and tags?
Thanks for the clarification, @saquetim!
I’m not sure what you mean here - could you clarify a little?
Docs Plugin, we can show tags by group in sidebar to filters.
WIth the new plugin can we do the same?
The new plugin cannot do that currently. It may be something we explore in the future, but for now it isn’t something we’re adding to it.
Yes, yes
thank you so much!
I must be really stupid, but I believe i did everything right, I named a topic to be the index for a category, and set the docs plugin to point to this topic, but i still don’t see a side bar. Is there a step-by-step demo maybe with screenshots? I’m stumped trying ot get a documentation category set up. Thanks!
