לא ניתן לראות מחרוזות i18n במהלך הפיתוח
When I start developing a new plugin, my dev environment does not pick up the client.en.yml strings that belong to the new plugin. It does pick up all other i18n strings, both from core and for other plugins.
I’ve had this before when introducing a new client.en.yml file and then the problem went away after a number of hours or after I did something (if only I knew what). When the problem goes away, it picks up updates to the i18n strings without any problems. It’s just like it takes something (or time) before the file is seen.
config/locales/client.en.yml
en:
  js:
    my_plugin:
      description_placeholder: "Enter description"
hbs file:
    <Input
      type="text"
      placeholder={{i18n "my_plugin.description_placeholder"}}
Browser shows:
[en.my_plugin.description_placeholder]
Admin - Customize - Text:
shows the correct string (!!!) with key js.my_plugin.description_placeholder
When I change the string in admin - customize - text, the browser shows the modification.
When I revert the changed string, the browser goes back to [en.my_plugin.description_placeholder]
I’ve restarted bin/ember-cli
I’ve restarted rails
When I modify the file, ember-cli notices and outputs file changed client.en.yml
Does this sound familiar to anyone?
Just now, a reboot resolved the issue…
This should solve the problem:
