Unable to add a Tag actor with ActivityPub plugin
A user, nathank, is experiencing an issue with the ActivityPub plugin, specifically when trying to add a Tag actor. The steps to reproduce the issue are:
  1. Go to /admin/plugins/ap
  2. Click on + Add Actor
  3. Select Tag (selecting Category works fine)
The issue results in no action being taken and an error in the console. nathank suspects this might be due to a change in core, as it works fine on Stable. pmusaraj has linked a potential fix: https://github.com/discourse/discourse-activity-pub/pull/116.
In two updated instances on tests-passed (one ‘clean’, with no other plugins or TCs), I’ve been unable to establish any actor.
  3. Select Tag or Category
Is this due to a change in core? It seems to work fine on Stable.
Thanks @nathank, this should fix that issue: FIX: Adding tags in admin UI by pmusaraj · Pull Request #116 · discourse/discourse-activity-pub · GitHub
This topic was automatically closed after 2 days. New replies are no longer allowed.
