작성 센터
Install this theme component
Hello :wave:
Compose Center is a place for all type of composing options. The idea was a place where you can easily handle your composing content.
Like:
  • New Topic
  • New Message
  • New Chat Message
  • Drafts
  • Pending Posts
I don’t want to hack the original layout and design so this made for the Default theme. Originally it can work pretty cool with a three column theme right sidebar. So it replaces the default + New Topic button with a Compose button. The content opens in DMenu and show a banner, profile avatar, user status, new topic/open draft, message, chat buttons, drafts and pending posts.
Quick buttons and links:
  • on banner My Drafts button: link to drafts
  • on banner pencil icon (edit): link to preferences/profile
  • on avatar (hover) pencil icon (edit): link to preferences/account
  • user status: opens user status modal
  • new topic/open draft button: opens topic composer
  • message button: opens pm composer
  • chat buttons: opens new chat message modal
The banner background is the blurred profile avatar if the user card background hasn’t setted up.
Default
With draft
With pending posts
User status
Theme Translations
:heart: Credit: I’ve integrated the New Topic Header Button theme component in it. This is inspired by Central theme profile block.
15개의 좋아요
Nice work Don, installed on my personal site and I really this feature. :clap:
I’m not getting the new topic button on the header though, even if I preview from the component in admin. :thinking:
4개의 좋아요
Thanks Lilly, I am glad you like it! :heart:
No, sorry I mean I integrate that component functionality in the DMenu. So the New Topic button code you see in DMenu is mostly coming from the New Topic Header Button theme component. :slight_smile:
4개의 좋아요
Hah, after I posted, I was wondering if I was just misunderstanding the OP. Thank you for clarifying. (And when I think about it, I’d prefer to not have it in the header anyways.)
I really like that composer modal and would like to be able to open it from the sidebar, but one can create a custom section to do the same things.
I like the look of the little pop-up you made :smiley:
4개의 좋아요
Is it possible to customize the color of this button to be the same as the button color of the theme you previously posted?
3개의 좋아요
I’ve found a bug that makes the customized state settings disappear after refreshing.
Hello :wave:
I’ve added to the button the create-topic id so it will use that style now. I’ve also noticed a missing point…this button is appears to anon too. I’ve fixed it. FIX: Hide Compose button for anons and adds create-topic id to it by VaperinaDEV · Pull Request #4 · VaperinaDEV/discourse-compose-center · GitHub
I think this is an issue with user status in core. I have already a topic about it here: User status stops working for admins but I have to investigate it more… If you navigate to a topic or somewhere then it will appear again. So this issue is not related with this theme component.
4개의 좋아요
Hello :wave:
I’ve merged an update to handle instances where chat is disabled. So now chat is not required to use this component. :slightly_smiling_face: Because of this I’ve changed the OP and added a Theme Creator link too.
https://github.com/VaperinaDEV/discourse-compose-center/pull/5
4개의 좋아요
Just FYI — came along with new multiple drafts. Not a major one.
2개의 좋아요
Thanks @Jagster, fixed by FIX: drafts label i18n · VaperinaDEV/discourse-compose-center@6a58764 · GitHub :slightly_smiling_face:
4개의 좋아요
What is interface_button_title translation/setting for? It does not seem to get used anywhere…
2개의 좋아요
Hello :wave: Yeah, it looks like it left from a previous version. I’ll remove it. :+1:
2개의 좋아요
I upgraded Diacourse recently, and at same time I lost translation of compose button.
No hurry.
2개의 좋아요
Hello, Is it fixed by this? Translation of Bookmark button is lost - #2 by david
1개의 좋아요
Yes, it did :+1:
1개의 좋아요
최근 이 컴포넌트에서 오류가 발생하기 시작해서 여기서 PR로 수정했습니다. :slight_smile:
1개의 좋아요
@Lilly 감사합니다 :hugs: 병합했습니다!
1개의 좋아요
