כמה הודעות שגיאה מציגות בשפה ברירת מחדל במקום בשפת המשתמש
סיכום מבוסס בינה מלאכותית
Moin reports that some error messages in the discussion platform appear in the default language (German) instead of the user’s chosen language (English). Specifically, the following error messages are affected:
  • The “you cannot vote on your own post” message appears in German.
  • The “you cannot undo your vote” message is partially translated, with the English message appearing when trying to add the same vote again, but the German message appearing when trying to change the vote.
  • The “you are only allowed to vote once” message also appears in German.
The one that tells you that you cannot vote on your own post uses German even though the interface is in English. You can notice that because “An error occurred” and the buttons below are all in English.
The message that you cannot undo your vote anymore works partly. When you click the same chevron you used for voting, so you are trying to add an upvote when you already added an upvote or add a downvote when you already added a downvote, it works. However, when you change your mind and try to use the other button, it fails.
The “you are only allowed to vote once” message is a little difficult to trigger. You need to wait until you are no longer allowed to change your vote. Then, first try to change your vote and then try the other button.
לייק 1
