אימות YML לפני הבנייה מחדש?
סיכום מבוסס בינה מלאכותית
YML Validation prior to rebuild?
TonyG experienced a 6-hour virtual downtime on their self-hosted Discourse installation after a rebuild due to a YAML syntax error in their app.yml file. They suggested implementing YML validation before a rebuild and a pre-processor to determine if a full rebuild is necessary after specific changes.
Other users responded with potential solutions: pfaffman mentioned a two-container setup can minimize downtime, while nwnuyhs suggested checking the file size to diagnose issues. Jagster pointed out that some errors, like the one TonyG encountered, may not be YAML syntax errors but still cause problems.
This is on a self-hosted Discourse installation in a private VPS with a typical Docker installation.
I did it again:
I waited through a two hour “flawless” update rebuild to v3.4.0.beta2-dev.
Then added a couple lines to app.yml and waited for another couple hours for another rebuild.
(Why separate the operations? Because a double whammy is never good if there is potential for errors.)
Then I found runtime errors in the log because I forgot spaces in app.yml (for MaxMind account and key).
So tonight I need to do yet another rebuild.
That’s over six hours of virtual downtime, compared to a WordPress or other CMS site that would only take a few minutes in the exact same scenario. This screams “bad UX” and thus “anti-marketing” - it’s just not good for the platform.
The only reason I had to do a second rebuild was because I added these blasted two lines. I really wish a full rebuild wasn’t necessary just because of this small change in the config file.
  1. Has there been any talk about doing a validation on the yml file before a rebuild? That simple feature would have eliminated a time consuming operation and subsequent issues.
  2. Has there been any talk about a pre-processor that determines if a full rebuild is required after specific changes?
  3. I’m surprised a YAML error didn’t get reported in the logs. Is there a reason why the runtime main .yml folder and perhaps others are not checked for syntactical errors? … Or do more experienced admins do their own linting before a rebuild? :thinking:
I’m hosting in Docker because I believe it’s “the easiest” platform if/when I pass this system on to someone else for maintenance. If that’s not correct, and I’ve opted for not only “not easiest” but also “slowest”, perhaps I should consider a different installation option.
Thanks!
A two container setup can build the new container while the old one keeps running, so there’s only a minute or so if downtime while the new container cracks up.
That’s a very kind rebuild time. I guess you’re on pi or something else that’s very slow?
Usually if there is a yml config issue you get notice right away.
You can check the file size use this code,then you can analyze if it is the problem of space
/var/discourse# du -sh /* | sort -h
Except with those two spaces with MaxMind. It goes thru but geo things doesn’t work. So it isn’t yml syntax error per se, but it is still an error :man_shrugging:
