אנחנו משדרגים את האיקונים שלנו ל-Font Awesome 6!
סיכום מבוסס בינה מלאכותית
Discourse is upgrading its icons to Font Awesome 6, with a phased rollout starting immediately. The update includes new icons, style changes, and renames, with automatic remapping of old icon names for backward compatibility. A deprecation warning system will be enabled soon, followed by the removal of old icon names and remapping by April 1, 2025, and error logging by May 2, 2025. Users and developers are advised to update their themes and plugins to use the new icon names, with guidance provided for identifying and fixing missing icons. Some users reported issues with specific icons like “bluesky” and “search,” which were resolved by using the correct prefix (e.g., fab-bluesky) or updating components. The community discussed the challenges of breaking changes, with some expressing frustration over the maintenance burden, while the Discourse team explained the necessity of such updates for long-term sustainability and technical debt management. awesomerobot, Jagster, ondrej, PatrickF, Moin, emonunix, LeoDavidson, and Jonathan_Potter contributed to the discussion.
What’s Font Awesome?
Discourse uses a free set of icons from Font Awesome throughout its interface. You see these on toolbars, badges, buttons, etc… here’s our composer toolbar:
Since 2018 we’ve been using Font Awesome 5 (original announcement), and in the meantime Font Awesome 6 has been released. Version 6 includes new icons, some general style updates, and renames.
As of today, Discourse will start using version 6 too! Specifically, version 6.6.0. This isn’t an enormous visual change, but you’ll notice some differences:
What does this upgrade involve?
This upgrade involves a number of renames to make things more consistent.
To support Discourse communities through the upgrade, changes will be rolled out in multiple phases:
:white_check_mark: Today - Font Awesome upgraded to v6, icons will be automatically remapped
:white_check_mark: Soon - deprecation messages will be enabled to help theme/plugin authors update their icon names
:white_check_mark: Q1 2025 - admin warning banner enabled for any remaining deprecations
:white_check_mark: 1st April 2025 - removal of automatic remapping and admin warning banner
:white_check_mark: 2nd May 2025 - removal of old icon names mapping and error level logging
I’m seeing a missing icon, how can I fix this?
  1. Open the browser developer tools, and find the relevant element with the missing icon.
  2. Note the current name of the affected icon, and look up the right icon name to update it to. The icon name mapping can be referenced at discourse/lib/deprecated_icon_handler.rb at fbc2cfb6185c00950da8e915b1a32546e7020913 · discourse/discourse · GitHub.
  3. Update the relevant theme/plugin that the element belongs to, or notify its developer to make the update.
If you need help with this, please feel free to create a Support topic, or contact your hosting provider in the normal way.
What do theme and plugin authors need to know?
The methods covered in Introducing Font Awesome 5 and SVG icons will still work for adding new and custom icons.
We have since removed the remapping of the old names, and if your theme/plugin is still using old names, you’ll see blank spaces where some of your icons used to be.
There are lots of new icons!
The upgrade from version 5 to 6 introduces hundreds of new free-to-use icons, almost 500 in total!
You can browse the full set here, this is sorted to show the newest additions first — and the search is very handy: Search Icons & Find the Perfect Design | Font Awesome
39 לייקים
Is this needed anymore:
@import url("https://use.fontawesome.com/releases/v5.13.0/css/all.css");
And should this be edited:
    api.replaceIcon('d-post-share', 'share-alt');
    api.replaceIcon('d-topic-share', 'share-alt');
    api.replaceIcon("far-beer", "beer");
</script>
2 לייקים
This is great! I can finally use the Icon I want for a category :tada:
6 לייקים
Looks like this might be related to Making tags look like real world tags - #11 by HeyRR… if you’re using CSS like content: "\f02b"; then yes you’ll still need this. This is using the icon font separately from our implementation (which uses SVG files directly)
This doesn’t need to be edited immediately, but based on the list of renames you should replace share-alt with share-nodes and beer with beer-mug-empty at some point within the next 6 months (the filled beer mug is a pro icon… I guess it’s not “free as in beer”)
6 לייקים
Perhaps. It was something that adviced more than once some years ago. I never really understood why, but I can copy&paste :squinting_face_with_tongue: But it has something to do with ability to use Font Awesome somewhere, anywhere or something.
But if I can’t use beer anymore I will start a mutiny with army of moomins :rofl:
3 לייקים
At the moment the shield icons are missing here at Meta.
6 לייקים
Fixed :tada:
7 לייקים
Thanks, it’s not clear to me if the upgrade to version 6 has been done or will be done? (I could’nt find the “bluesky” :butterfly: version 6 icon after upgrading my site, it’s why I ask…)
לייק 1
Once you update your site, your icons will be FA6 and automatically remapped by Discourse.
2 לייקים
Yes it’s what I expected, but this icon cannot display (I use it in the header icons links component)
לייק 1
I’ve found the icon on 6.6.0
As its not a icon used in Discourse, is it in your svg icon subset in site settings?
לייק 1
No, I am adding it with this syntax: “fa-bluesky” in the resources of the component, but it’s not sufficient. I’ll look at that svg resources thing, I am not familiar with that.
(update), apparently we are talking about the same thing, yes it is added in the resources…
לייק 1
you might need to do fab-bluesky, because it’s part of the brand set
5 לייקים
Thanks it works specifying fab-bluesky in the svg resources and in the custom header links editor, which I never needed to do before. In the custom header links component, I never specified the prefix “fa”, for the bluesky icon I needed to specify “fab-bluesky”. The main thing is that it works ! Thanks.
2 לייקים
I upgraded and icons changed. The thing that was bothering me most, because I’m a bit scared of my users (those ladies are wonderful, but if they get upset…) is what happens with reactions, but that is a different world, right? Anyway, everything went smoothly.
4 לייקים
Looks like a cool upgrade! I love the updated rounding. Didn’t know it was a change I wanted.
2 לייקים
Most importantly, the new version uses the correct Fedora logo rather than an unauthorized approximation that was giving our designers aneurisms.
11 לייקים
9 posts were split to a new topic: Some icons not showing up after upgrade
Will the official Category Icons and Tag Icons theme components be updated to use the new Font Awesome 6 names?
I think they still currently use FA5
3 לייקים
These theme components use the icon system built into Discourse, so I don’t believe they’ll need an update to be compatible — they should automatically use the new icons.
7 לייקים
