개인 메시지용 양식
Is there any way to make Introducing Experimental Form Templates - announcements - Discourse Meta work for Personal messages also?
Hello Toni,
As far as I’m aware, there isn’t such a feature yet. Its not the same but would Creating pre-filled personal message links work?
Thanks for the suggestion @ondrej
It’s a simple solution, but users make it problematic.
Many don’t fill in the questions in the template, some simply delete it, put answers in the wrong place or don’t even bother reading/following it.
That’s why I like the required fields approach where they have no choice but to fill them.
그분의 답답한 마음을 이해합니다. 제 생각에는 사용자들이 중요한 내용을 99%의 경우 읽지 않는 것 같습니다.
가장 좋은 방법은 Contribute > Feature 요청을 만드는 것 같습니다.
하지만 이것이 어떻게 작동할까요? 예를 들어, 현재 양식 템플릿은 범주별로 고정되어 있습니다. 그러나 개인 메시지의 경우, 그룹 받은편지함으로 양식 템플릿을 생성할 수 있도록 하는 것이 더 합리적일 것입니다.
Because they don’t understand why it would be important. And 99% of the cases they are actually right :smirking_face: It is just important for admins and/or the company.
And that is the real issue to solve.
But forcing is one solution.
In my case it’s important for them. If they don’t say what product or version they use we’re not able to assist them properly. These are the fields I’m trying to get from them.
