AI Helper Proeflezen toont geen verschillen bij selectie
Instead of seeing the AI icon in my composer window, I see it on the gear icon (not sure why):
When I choose Proofread (Corregir el texto), I can see the diff between the original and the new version. However, when I select text and click the AI overlay icon, and choose Proofread, the diff doesn’t show up:
Hey @Nacho_Caballero,
As of commit 9cd14b0, we’ve moved the AI composer helper from being invoked via text selection popup to the selection toolbar menu.
You should be able to select text and invoke it like this:
Can you please confirm your plugin is up to date? Selecting an option here should bring up the diff modal.
@Nacho_Caballero I am assuming this is fixed, flag to reopen if still an issue.
