사람들을 초대할 수 있는 섹션으로 이동하는 단계별 지침을 어디서 찾을 수 있나요?
I can not find the section to invite people?
The avatar user menu on the top right corner has the link
Here are some topics to help
We will soon be putting a link directly to the invite popup in the sidebar. It will be displayed above the … on new sites, then hidden behind the … once bootstrap mode has ended.
The invite popup is also getting an update, to hide all the options except the easy-to-use and now more commonly recognized “copy link to share” method.
I’ve not seen this option for quite some time on my site. I can see its part of invitations I created a while ago (I keep extending the date).
Was it removed?
It is still there
Did you enable the must approve users site setting?
Yes I did! And I see if I toggle it off, the arrive at topic returns! I had not idea these were connected. I set the must approve setting on seeing an increase of new accounts that looked a bit suspicious. I can live without it, just helpful to see new accounts at the door.
