도움! Android에서 Discourse 앱 연결 오류
I am trying to connect the “Tecnoblog Comunidade” to the Discourse app on Android 14, but when I click the button to connect the community within the Discourse app, an error screen appears, and I don’t know how to fix it.
Error: “{“errors”:[“param is missing or the value is empty: public_key”]}”
Community: https://comunidade.tecnoblog.net
Does this happen when you try to connect any other forum?
2개의 좋아요
Only with this community is the error happening; when I try to connect to others, it works normally.
1개의 좋아요
This is possibly a Cloudflare problem.
(I get the same result btw)
2개의 좋아요
Is there any solution on the way? It would be great to use it in the Discourse app, and it seems like it’s only happening with this community, @supermathie @sam
1개의 좋아요
It’s best to get in touch with the administrators of “Tecnoblog Comunidade” - the problem is likely with their Cloudflare setup. Feel free to direct them to Using Discourse with Cloudflare: Best Practices.
If they can temporarily disable Cloudflare and successfully add the site to Hub with it off, that’ll confirm the theory.
1개의 좋아요
Closing since the problem here needs to be fixed by the admins of Tecnoblog Comunidade. Looks like something in their setup is stripping parameters from requests.
