Users can no longer edit any posts since 3.4.0.beta3-dev
Users reported an issue in Discourse 3.4.0.beta3-dev where editing posts, including wiki posts, failed. Clicking Edit opened the revision history modal, but the edit interface did not appear. The error log indicated a NoMethodError in render_json_dump, traced to the discourse-reactions plugin. xandra.cc provided the error details and backtrace. merefield suggested disabling the plugin, and Moin pointed to a recent fix in the plugin (https://github.com/discourse/discourse-reactions/pull/314). xandra.cc confirmed the issue was resolved by updating the plugin.
We updated to 3.4.0.beta3-dev this morning and ever since, we’ve been unable to edit any of our posts (including wiki posts).
When you click the Edit button, the History, last 100 revisions modal appears, but once you hit Edit Post, the modal disappears. This happens anytime you try to edit any of your posts or wiki posts.
This is from /logs associated with the time when tried to edit a post:
NoMethodError (undefined method `[]' for nil)
app/controllers/application_controller.rb:528:in `render_json_dump'
app/controllers/application_controller.rb:1052:in `render_post_json'
app/controllers/posts_controller.rb:993:in `display_post'
app/controllers/posts_controller.rb:297:in `show'
app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
app/controllers/application_controller.rb:424:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:399:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:35:in `call_app'
lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:22:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/processing_request.rb:12:in `call'
lib/middleware/request_tracker.rb:360:in `call'
Backtrace:
plugins/discourse-reactions/plugin.rb:115:in `block (3 levels) in activate!'
activerecord (7.1.4) lib/active_record/relation/delegation.rb:100:in `each'
plugins/discourse-reactions/plugin.rb:107:in `reject'
plugins/discourse-reactions/plugin.rb:107:in `block (2 levels) in activate!'
(eval at /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):87:in `_fast_attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:347:in `as_json'
activesupport (7.1.4) lib/active_support/json/encoding.rb:23:in `encode'
activesupport (7.1.4) lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:331:in `to_json'
multi_json (1.15.0) lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json (1.15.0) lib/multi_json/adapter.rb:25:in `dump'
multi_json (1.15.0) lib/multi_json.rb:139:in `dump'
actionpack (7.1.4) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.1.4) lib/abstract_controller/base.rb:224:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.1.4) lib/abstract_controller/callbacks.rb:259:in `block in process_action'
activesupport (7.1.4) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
i18n (1.14.6) lib/i18n.rb:353:in `with_locale'
activesupport (7.1.4) lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport (7.1.4) lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack (7.1.4) lib/abstract_controller/callbacks.rb:258:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/rescue.rb:25:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/instrumentation.rb:74:in `block in process_action'
activesupport (7.1.4) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.1.4) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (7.1.4) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.1.4) lib/action_controller/metal/instrumentation.rb:73:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/params_wrapper.rb:261:in `process_action'
activerecord (7.1.4) lib/active_record/railties/controller_runtime.rb:32:in `process_action'
actionpack (7.1.4) lib/abstract_controller/base.rb:160:in `process'
actionview (7.1.4) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack (7.1.4) lib/action_controller/metal.rb:227:in `dispatch'
actionpack (7.1.4) lib/action_controller/metal.rb:309:in `dispatch'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:51:in `block in serve'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:131:in `block in find_routes'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:124:in `each'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:124:in `find_routes'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:882:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.1.4) lib/action_dispatch/http/permissions_policy.rb:36:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
activesupport (7.1.4) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (7.1.4) lib/action_dispatch/middleware/callbacks.rb:28:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
logster (2.20.0) lib/logster/middleware/reporter.rb:40:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/request_id.rb:28:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/remote_ip.rb:92:in `call'
railties (7.1.4) lib/rails/engine.rb:536:in `call'
railties (7.1.4) lib/rails/railtie.rb:226:in `public_send'
railties (7.1.4) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
We assume this has something to do with the update that just occurred but wanted to raise the flag because this is a pretty critical bug for us. Could this be on our end?
What happens if you remove the
Which version of the reactions plugin is installed?
There was a fix about 12 hours ago
Thank you! This was the fix.
Thank y’all for your help!
