צריך להקים discourse בשרת Ubuntu 22.04 לשימוש הארגון שלי
Dear All,
I need help to setup discourse application at my Ubuntu 22.04 server (Couple of other applications are also running on the same server) . So, this means i need discourse stable version to install for production purpose but my main challenge is that i can’t setup domain here as my organization needs to keep it as internal use by accessing server private IP.
So direct docker container setup is not working for me here, do i have any other options available here to setup discourse as production version with IP of the server? Please suggest, thanks for your valuable feedbacks in advance.
Regards,
Ravi Kumar
You’ll need to set up a reverse proxy that does https termination.
Run other websites on the same machine as Discourse
