I’m trying to put a template in a specific plugin outlet in my javascripts/discourse/initializers/persistent-banner.gjs.
Code:
import Component from "@glimmer/component";
banner_plugin_outlet = settings.banner_position
export default apiInitializer("1.14.0", (api) => {
try {
api.renderInOutlet(
banner_plugin_outlet,
class persistentbanner extends Component {
get bannerIsFilled() {
if (settings.banner_text_content == "") {
return false;
} else if (settings.banner_visible == "hide") {
return false;
} else {
return true;
<template>
{{#if this.bannerIsFilled}}
<div class='persistent-banner'>
<p>
{{html_safe (theme-setting 'banner_text_content')}}
</p>
</div>
{{/if}}
</template>
} catch (e) {
console.log(e);
But the HTML in the <template> tag won’t display at the outlet location. In fact, it won’t display at all. What am I doing wrong?
Repo link: GitHub - NateDhaliwal/discourse-persistent-banner: A theme component for Discourse that cannot be closed by the user.
merefield
(Robert)
13 באוקטובר, 2024, 9:42am
Don’t use an initialiser for this? Use the connectors folder. There are loads of examples.
The reason is that there are different outlets that can be selected.
I adapted this code from Notification Banner’s repo.
merefield
(Robert)
13 באוקטובר, 2024, 10:39am
4
Ah got it. Yes that makes sense. Sorry wasn’t sure if your functional intention. I should have read the code in more detail.
merefield
(Robert)
13 באוקטובר, 2024, 11:19am
6
A few things to get you going again:
this file has an missing closing round bracket at the end of your
apiInitializer call - that will just not work.
On fixing that issue I see more errors.
banner_plugin_outlet is not declared - you need a const here.
you assign it twice? you don’t need it twice I suspect
try {
You are missing imports:
import { htmlSafe } from "@ember/template";
import themeSetting from "discourse/helpers/theme-setting";
… but I couldn’t get themeSetting to work as a helper here. No error, just blank, so try this code instead:
get bannerTextContent() {
return settings.banner_text_content;
<template>
<p>
{{htmlSafe this.bannerTextContent}}
Always check the console for errors.
I imported htmlSafe and this worked like a charm!
Thanks so much!
david
(David Taylor)
14 באוקטובר, 2024, 10:38am
8
Robert:
<template>
<p>
Yeah, the helper doesn’t work (and isn’t needed) in gjs. Defining a getter is fine. But if you want to avoid that, you can reference the settings “global” directly from the template:
<template>
{{htmlSafe settings.banner_text_content}}
</template>
merefield
(Robert)
14 באוקטובר, 2024, 10:44am
9
Thanks. That didn’t seem very transparent!
david
(David Taylor)
14 באוקטובר, 2024, 11:01am
10
Yeah that’s fair. Let’s improve the error messages:
main ← theme-helper-errors
merged 03:00PM - 14 Oct 24 UTC
theme-setting and theme-i18n are not needed in `.gjs` files. This commit adds mo… re helpful error messages to direct developers to the modern alternatives.
<img width="740" alt="SCR-20241014-kvmu" src="https://github.com/user-attachments/assets/810218e7-ca70-4611-b0af-85d4323543b2">
<img width="722" alt="SCR-20241014-kvau" src="https://github.com/user-attachments/assets/219ed2bc-7a39-46ac-9f07-46aa798db319">
merefield
(Robert)
14 באוקטובר, 2024, 11:58am
11
Thank you. This really helps with the developer experience.
Which as we know has improved dramatically with.gjs over widgets.
however
There are lots of very odd errors you can get when using gjs components that do not make finding the issues very easy.
For example, lets mess up the helper name:
{{html_safe this.bannerTextContent}}
Leads to the classic:
program.js:100 Uncaught (in promise) TypeError: Invalid value used as weak map key at WeakMap.set (<anonymous>)
(this also happens here with a valid name if you forget the import)
Say what?! There are lots of these examples.
I guess this is a downside of using a framework?
david
(David Taylor)
14 באוקטובר, 2024, 1:25pm
12
Ouch, that’s a bad one!
When I try locally, I see:
Where did you see the WeakMap error? On a production site? If so… perhaps this is one of the checks which ember optimizes out of production builds to improve performance.
If you can, I’d always recommend developing themes/plugins against a proper development environment - there are lots of cases like this where the experience will be better.
merefield
(Robert)
14 באוקטובר, 2024, 1:37pm
13
Yes, Production site using the Theme CLI ( which I guess is one of its downsides, despite its otherwise it’s a great workflow?)
That makes total sense.
Yes, with plugins it’s my goto but with TCs there’s a good temptation to dev against a Production site because of the immediacy of feedback (if not always very helpful!)
But I’ve just realised, you can enter localhost with the CLI and it works.
So duh!
I will use that going forward!
I have no idea why I thought that wouldn’t be possible
As usual, thanks for your help that’s saved me a lot of time (in the future )
david
(David Taylor)
14 באוקטובר, 2024, 2:16pm
14
Yup! Localhost with a theme-cli is how I try to work, and what I recommend to other people. We can definitely do better at documenting these recommended workflows
The other tip is that discourse.theme-creator.io runs with development-mode Ember assets. So that should have the nicer error messages as well.
