יצירת תוסף או רכיב בתשלום
סיכום מבוסס בינה מלאכותית
Epoch is seeking paid development for three Discourse features: a user ranking-based color-coding system for usernames across the site, a dynamic collapsible sidebar for categories, and assistance with customizing the login page. The ranking system would prioritize colors based on the highest user group rank, with sorting capability. The sidebar should automatically detect and organize primary and subcategories without manual configuration. jericson responds by noting that Discourse already supports group flair for color coding but lacks universal display, particularly in chat, and suggests a Data Explorer report for ranking sorting. For the sidebar, they reference a similar existing component and note potential customization needs. Regarding the login page, they direct Epoch to a related discussion for guidance. Epoch mentions a tight budget of around $200, and jericson offers to provide a quote via direct message.
What would you like done?
3 different plugins or components
  1. I would like a component that will color code names of users throughout the entire site based on the group they are in (chat, topics, card ect.) I would like this based on a ranking set in the settings and maybe a color selector if easy?
Example:
Admin Blue > would be rank one
Moderator > would be rank 2
Trust level 3 > Would be rank 3
Custome group > Would be rank 4
Trust level 2 > Rank 5
Trust level 1 > Rank 6
The color would be dictated by the highest rank.So if a user was in the custom group but has not reached rank 3 yet the color would be the custom groups color but if they reach rank three they would get the rank three color.
I would like to be able to sort the ranks.
  1. Collapsable sidebar categories. I would like the sidebar to show all categories at all times and for a primary category to have toggle to expand and show its subcategories. I would very much like this to be dynamic with no settings, just turn it on and it finds the categories and subcategories and creates the sidebar.
  2. A custom login page? I dont know if i actualy need a component for this or just some assistance finding where this is and how to change it without destroying everything else :smiley:
When do you need it done?
As soon as you can, no need to rush it.
What is your budget, in $ USD that you can offer for this task?
Working on a tight budget maybe a couple hundred dollars give me a quote and we might be able to work something out.
2 לייקים
Out of the box, Discourse has a group flair system that you could assign a number/color to each group. So here’s what I might look like as a “rank 2” (moderator) in your system:
Screenshot 2024-10-14 at 3.12.36 PM
This is a user-selected option, though, so I could choose to use the rank 6 (trust level 1) flair. It also doesn’t show up everywhere. In particular I don’t think it shows up in chat.
This wouldn’t be hard to get from Data Explorer. Or do you want to have some sort of public report?
This sounds a bit like a fairly new component:
Might require some adjustment and/or added logic to do what you are asking.
This depends on what you want to accomplish. See a similar question:
I’ll send a DM.
2 לייקים
