תצוגת מקדימה ב-Github עם עוגנים should להציג את העוגן במקום את חודרת הקובץ
סיכום מבוסס בינה מלאכותית
The discussion addresses a potential bug where GitHub onebox previews render the top of a file instead of the specific section indicated by an anchor link. Atemu reports that linking to a file with a section anchor (e.g., #development) currently displays the beginning of the file rather than the targeted section. nat tags the issue with #pr-welcome to encourage community contributions to fix this behavior.
jahan_gagan provides technical insight, explaining that Discourse fetches content via raw.githubusercontent.com, which serves plain text. While line-specific anchors (e.g., #L23) correctly jump to the specific line, section anchors do not translate directly to line numbers in the raw fetch. The commenter suggests using explicit line numbers as a workaround to preview specific sections, such as https://github.com/discourse/discourse/blob/main/README.md#L23.
When you link a Github file with an anchor, the preview which Discourse renders is of the top of the file rather than from the anchor on.
See for instance:
This should preview show the development section, not the top of the readme.
(Not sure whether this is actually a bug.)
3 לייקים
I’ve added a pr-welcome here if you’d like to help improve this. :slight_smile:
לייק 1
I reviewed this PR and noticed that Discourse attempts to serve content directly from the repository using https://raw.githubusercontent.com , which provides a plain, unstyled raw file (e.g., https://raw.githubusercontent.com/discourse/discourse/main/README.md#development ). For line-specific references (like #L-{line-number} ), it jumps directly to the specified line in the file to display the content. To preview a specific section (e.g., #development , #requirements ), you can specify the line number as shown below:
לייק 1
