Hello,
I have cloned GitHub - discourse/discourse_docker: A Docker image for Discourse · GitHub inside samples directory i am able to see standalone.yml, web_only.yml so can you guide me for web_only.yml file how to install.
Thanks.
The discussion revolves around setting up Discourse using a web_only container setup. Aniket initially sought guidance on installing via web_only.yml, and Moin directed them to the two-container setup documentation, noting that ./discourse-setup --two-container is required when no app.yml exists. pfaffman confirmed this approach. After troubleshooting, Aniket reported success but encountered issues with images and logos not loading, which pfaffman attributed to storage paths. Aniket then asked about configuring S3 for uploads instead of local storage in the web_only setup.
There is some information about the two-container setup in this topic:
The general install guide is here:
You can run discourse-setup with the --two-container switch.
I had tried but not working.
You need to run it when no app.yml exists.
What happens when you try?
Now its working fine thanks.., but one issue i have, earlier i have used app.yml file which is standalone setup, now i tried using web_only.yml in that i have configured RDS database and redis url.
now for web_only setup working but unable to load images and logos what i have defined in my earlier setup.
You probably need to either move them to web_only or change the bind path in the yml file.
instead of using local storage for uploads, how we configure s3 bucket with web_only container
