tsParticles niet gedefinieerd, hoewel het dat wel is
I am trying to put the tsParticles ‘links’ animation in my Discourse theme.
However, the Console says that:
theme-field-96515-common-html-script-1.js:36 Uncaught (in promise) ReferenceError: tsParticles is not defined
    at theme-field-96515-common-html-script-1.js:36:13
    at HTMLDocument.<anonymous> (theme-field-96515-common-html-script-1.js:36:13)
But you can see that in my code, it clearly is, at the top.
Here is my code:
<script type="text/discourse-plugin" version="1.14.0">
  var script = document.createElement('script');
  script.src = "https://cdn.jsdelivr.net/npm/@tsparticles/preset-links@3.0.2/tsparticles.preset.links.bundle.min.js";
  document.head.appendChild(script);
  const showLinks = settings.show_tsParticles_links_animation;
  if (showLinks) {
    document.addEventListener("DOMContentLoaded", function() {
      var elements = document.querySelectorAll('section#main');
      elements.forEach(function(el) {
        var wrapper = document.createElement('div');
        wrapper.className = 'wrapper';
        el.parentNode.insertBefore(wrapper, el);
        wrapper.appendChild(el);
      var elements = document.querySelectorAll('div#main-outlet-wrapper');
        wrapper.className = 'content';
      (async () => {
        await tsParticles.load({
          options: { preset: "links" },
          background: {
            "color": {"value":"#0d47a1"}
</script>
Moreover, when looking at he <head> of the page, this tag is there.
Looks like a race condition where the tsParticles.load() is running before the js has finished loading.
Since you’re already in the <head> element, you can probably just pull out the code for making a script tag for tsParticles, and just make it an actual script tag so that it loads with the page instead of after page load finishes.
If you need to keep the script load in the JS, you can run the code on the load event.
const script = document.createElement('script');
script.addEventListener("load", () => {
      console.log("called", tsParticles);
      initTsParticles();
function initTsParticles() {
  tsParticles.load({
That works, thanks so much!
