A instalação do desenvolvimento falha ao executar bin/rails db:migrate
Basically, I am trying to do a dev install on my Pi, following this guide. I ran bin/rails db:create, which worked fine. Then when trying to run bin/rails db:migrate, it ends by saying something about oxipng binary file not working? It tells me to either put a proper binary file or use some command (I cannot remember it exactly, I’ll tell you why).
But, um, my VNC lagged out when doing this (I think the processing was too much? I did a bin/ember-cli -u even with this oxipng thing. Anyway, I then clicked on something and all I say was a grey screen. I closed the VNC session and tried to reconnect. Nothing happened for a long time. I disconnected and reconnected my Pi (yes, force shut down. Very bad.). As such, I don’t know that oxipng message much.
Tried again to run bin/rails db:migrate, and this was the error (same error as well when running RAILS_ENV=test bin/rails db:create db:migrate):
== 20241024093027 RemoveCategoryExpertsWebHookEventTypes: migrating ===========
-- execute("DELETE FROM web_hook_event_types WHERE (name, id) IN (('category_experts_approved', 1901), ('category_experts_unapproved', 1902))")
   -> 0.0011s
== 20241024093027 RemoveCategoryExpertsWebHookEventTypes: migrated (0.0029s) ==
/home/natedhaliwal/discourse-f/app/models/post_action_type.rb:16:in `expire_cache'
/home/natedhaliwal/discourse-f/app/models/post_action_type.rb:42:in `reload_types'
/home/natedhaliwal/discourse-f/app/models/flag.rb:37:in `reset_flag_settings!'
(eval):78:in `block (2 levels) in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:46:in `eval'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:46:in `block (2 levels) in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:58:in `block in open'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:57:in `open'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:36:in `block in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activesupport-7.1.4.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/transactions.rb:212:in `transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:35:in `run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:26:in `block in run'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:25:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:25:in `run'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/discourse-seed-fu.rb:29:in `seed'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:264:in `block (2 levels) in <main>'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:53:in `block in synchronize'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:49:in `synchronize'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:34:in `synchronize'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:234:in `block in <main>'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:27:in `block (2 levels) in perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:27:in `block in perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:44:in `block in with_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/rake_module.rb:59:in `with_application'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:41:in `with_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:20:in `perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:156:in `invoke_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:73:in `block in invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:149:in `with_argv'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:69:in `invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands.rb:18:in `<main>'
<internal:/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
bin/rails aborted!
ActiveRecord::RecordNotFound: Couldn't find Upload with 'id'=-6 (ActiveRecord::RecordNotFound)
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:119:in `resolve_original'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:71:in `block in ensure_optimized!'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:70:in `each'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:70:in `ensure_optimized!'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:272:in `block (2 levels) in <main>'
Tasks: TOP => db:migrate
When running it with --trace, I get:
natedhaliwal@raspberrypi:~/discourse-f $ RAILS_ENV=test bin/rails db:create db:migrate --trace
** Invoke db:create (first_time)
** Invoke db:force_skip_persist (first_time)
** Execute db:force_skip_persist
** Invoke db:load_config (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute db:load_config
** Execute db:create
Database 'discourse_test' already exists
Database 'discourse_test_multisite' already exists
** Invoke db:migrate (first_time)
** Invoke set_locale (first_time)
** Execute set_locale
** Invoke assets:precompile:theme_transpiler (first_time)
** Execute assets:precompile:theme_transpiler
** Execute db:migrate
bin/rails aborted!
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/core.rb:253:in `find'
Any thoughts on what I should do?
Hmm, a resposta provavelmente é esta linha:
Você removeu um ícone recentemente?
Um ícone? Você quer dizer como um ícone de imagem (por exemplo, FA)?
Abra o console do Rails e inspecione a tabela uploads para verificar se o ID = -6 está faltando:
RAILS_ENV=test bin/rails console
Upload.find_by(id: -6)
O erro indica que o registro com ID = -6 foi excluído. Você precisará atualizar os dados de seed ou os fixtures de acordo em seu ambiente de teste.
Olá, estou enfrentando esse problema também, mas parei antes de o instalador terminar, então não tenho bin/rails… como posso consertar isso. E não consigo entrar no aplicativo (./launcher enter app), a pasta bin está vazia.
@woozievert, por favor, compartilhe o rastreamento detalhado do seu erro
mesmo erro:
FAILED
Pups::ExecError: cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate' falhou com retorno #<Process::Status: pid 1962 exit 1>
Localização da falha: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec falhou com os parâmetros {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
bootstrap falhou com código de saída 1
** FALHA AO INICIAR ** por favor, role para cima e procure por mensagens de erro anteriores, pode haver mais de uma.
./discourse-doctor pode ajudar a diagnosticar o problema.
ActiveRecord::RecordNotFound: Não foi possível encontrar Upload com 'id'=-6 (ActiveRecord::RecordNotFound)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.1/lib/active_record/core.rb:253:in `find'
/var/www/discourse/lib/site_icon_manager.rb:119:in `resolve_original'
/var/www/discourse/lib/site_icon_manager.rb:71:in `block in ensure_optimized!'
/var/www/discourse/lib/site_icon_manager.rb:70:in `each'
/var/www/discourse/lib/site_icon_manager.rb:70:in `ensure_optimized!'
/var/www/discourse/lib/tasks/db.rake:272:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:234:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
Tarefas: TOP => db:migrate
(Veja o rastreamento completo executando a tarefa com --trace)
Desculpe, postei aqui e esqueci de responder.
Eu executei isso e obtive nil.
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:37:in `require'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails aborted!
natedhaliwal@raspberrypi:~/discourse-f $ RAILS_ENV=test bin/rails console
Loading test environment (Rails 7.1.4.1)
irb(main):001> Upload.find_by(id: -6)
=> nil
irb(main):002>
Em qual etapa você está atualmente? Você já clonou o Discourse?
Estou usando a instalação do docker
Acabei de me deparar com isso ao criar um novo banco de dados local e migrar.
Infelizmente, acho que foi introduzido por FIX: reset cache after flags are seed by lis2 · Pull Request #28801 · discourse/discourse · GitHub. Migrações totalmente novas do zero não são mais possíveis.
@kris.kotlarek, você poderia dar uma olhada, por favor? Acredito que tocar no cache do Redis no inicializador possa ser o problema.
Obrigado pelo relatório @NateDhaliwal
Kris corrigiu o problema com
Devemos estar bem agora!
