I did not config any stuff related highlighting and highlighting is not working on my forum.
how I coding
Showing
Here is my setting
Yt.w reported that syntax highlighting wasn’t working on their Discourse forum despite having configured languages like Ruby and Python. They shared screenshots showing their settings and code display, noting that the HTML appeared correct but highlighting failed. Later, Yt.w identified the issue as a CORS error triggered by a malformed module specifier in formatter.js, specifically referencing a path starting with /highlight-js/... from a cross-origin script. After investigation, Yt.w resolved the issue by modifying /lib/highlight_js.rb to prepend https:// to the generated path, ensuring the browser could correctly resolve the asset URL. This fix addressed the CORS restriction by making the path absolute and protocol-relative, allowing the highlight.js bundle to load properly.
r
the html code looks correct on my site
Looks like it was a CORS problem, any one can help me to solve it?
formatter.js:383 Uncaught (in promise) TypeError: Failed to resolve module specifier '/highlight-js/xxx.jp/9797975efac87d28baa695ae13ca72ccaf5120f5.js'. The base URL is about:blank because import() is called from a CORS-cross-origin script.
at g (formatter.js:383:1)
at m (formatter.js:383:1)
at h (formatter.js:383:1)
at p (formatter.js:383:1)
at topic-link.js:14:1
at formatter.js:383:1
at composer.js:867:1
at Array.forEach (<anonymous>)
at k._decorateAndAdopt (composer.js:867:1)
at k.init (composer.js:867:1)
at e (jquery.js:10:1)
at Object.e [as render] (jquery.js:10:1)
at jquery.js:10:1
at e.exports (jquery.js:10:1)
at jquery.js:10:1
at Object.l [as patch] (jquery.js:10:1)
at jquery.js:10:1
at e.rerenderWidget (user-status-bubble.js:12:1)
at invoke (backburner.js.js:280:1)
at h.flush (backburner.js.js:197:1)
at p.flush (backburner.js.js:358:1)
at B._end (backburner.js.js:798:1)
at B._boundAutorunEnd (backburner.js.js:523:1)
self solved
I changed /lib/highlight_js.rb
from
def self.path
"/highlight-js/#{Discourse.current_hostname}/#{version SiteSetting.highlighted_languages}.js"
to
def self.path
"https://#{Discourse.current_hostname}/highlight-js/#{Discourse.current_hostname}/#{version SiteSetting.highlighted_languages}.js"
