Ezoic 사용 시 Google 검색 URL 재작성 및 리다이렉트 중단 방법
I have forum related qna name zapask.com .
The problem is when visitors coming from google search url automatically rewrite url and redirects and give private page . Please help me its urgent i don’t wanna lose my google traffic.
Please check give me solution
Where does it redirect to?
autometicly rewrite url : like this “https://zapask.com/t/does-gina-rodriguez-speak-spanish-fluently/12030/t/does-gina-rodriguez-speak-spanish-fluently/12030
when visitors come from google search
Very odd. It seems to have duplucated the route twice.
Could you share a screenshot of the google page that you clicked on?
see before click url also show by google correct
after click its rewrite URL
It start happening automatically I don’t have changes in the website only adding QnA database
I check other device other internet its happens everywhere
I just figured out what happened. its because of Cloudflare. Just Solved Thanks for Reconising
Would you mind sharing what exactly you did? Was it something specific you had to disable? Maybe someone else will have the same problem.
last day I just joined the media publisher network Ezoic. they access my Cloudflare account and change my DNS to Their DNS Setting. I just Reverted to my original DNS settings.
:warning: Be aware! We had a number of clients having the same issue and Ezoic keeps reverting those settings back to their service automatically. You should revoke their Cloudflare API access, otherwise you’ll be having the same issue next week.
