Summary
Postman is a way to easily construct and test requests against an API.
Configuring with Discourse
After opening Postman, click Create Workspace:
Choose Blank workspaceand click Next.
Title it Discourse APIand select Create:
Click Collections:
Click Import:
Paste https://docs.discourse.org/openapi.json(which is the “Download” URL shown on docs.discourse.org):
Choose to import as a Postman Collection:
Create a new Environment
Click on EnvironmentsandCreate Environment. This will hold variables specific to the instance you’re testing. For this example, we’ll usetry.discourse.org.- add a new variable: defaultHostwith the valuetry.discourse.org:
- select the try.discourse.orgenvironment from the ⑤ Environment dropdown
Hello World!
Let’s try a request!
- Select Collections→categories.json→Retrieves a list of categoriesand click Send. You should see the result:
Add authentication to requests
To use the API with API key authentication:
Add the following variables to this or a new environment: - api-username
- api-key
 (their values must of course be valid for the site you are querying)
Add a script to the collection
 SelectCollections→Discourse API Documentation→Scripts→Pre-requestand paste the following:pm.request.headers.add({ key: "api-key", value: pm.variables.get("api-key") }) pm.request.headers.add({ key: "api-username", value: pm.variables.get("api-username") })
