Productie-installatie op 3.4.0.beta2-dev mislukt bij het updaten naar 3.4.0.beta2
User manton reports ongoing update failures on Discourse 3.4.0.beta2-dev, citing a missing chunk.0df757 file and system resource metrics. david suggests re-running the update or checking for concurrent processes, but manton confirms a standard install with no concurrent updates. david recommends a CLI rebuild (./launcher rebuild app), which manton successfully performs. During the rebuild, a post-install warning notes Ruby 3.0.2 will be unsupported after April 2025. manton asks how to upgrade Ruby, suspecting it may be bundled with Discourse. david questions whether the Ruby version was checked inside the container, as only the container’s Ruby matters. manton confirms a clean git status from a fresh install (June 2024). Separately, hhf.technology encounters a Docker API version error (1.43 vs required 1.44), which Ed_S attributes to outdated Docker or OS — though hhf.technology disputes this and later reports the issue resolved without opening a new topic hhf.technology. The core issue for manton remains unresolved regarding the Ruby version and missing asset chunk, pending confirmation of whether the reported Ruby version is from inside the container.
Good evening,
Once again, I am having update issues.
Server system load:
System load: 0.15
Usage of /: 56.4% of 157.22GB
Memory usage: 34%
Swap usage: 42%
Processes: 197
What is recommended from here? Seems to report a missing chunk.0 file
Logs:
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 554
Waiting for Unicorn to reload.
Waiting for Unicorn to reload..
Waiting for Unicorn to reload...
Waiting for Unicorn to reload....
Waiting for Unicorn to reload.....
Waiting for Unicorn to reload......
Waiting for Unicorn to reload.......
Waiting for Unicorn to reload........
Waiting for Unicorn to reload.........
Waiting for Unicorn to reload..........
Waiting for Unicorn to reload...........
Waiting for Unicorn to reload............
Waiting for Unicorn to reload.............
Waiting for Unicorn to reload..............
Waiting for Unicorn to reload...............
Stopping 7 Unicorn worker(s), to free up memory
Stopping job queue to reclaim memory, master pid is 971166
$ cd /var/www/discourse/plugins/docker_manager && git fetch --tags --prune-tags --prune --force
$ cd /var/www/discourse/plugins/docker_manager && git reset --hard HEAD@{upstream}
HEAD is now at 540a064 FIX: Minimize database access following `db:migrate` (#247)
$ bundle install --retry 3 --jobs 4
Bundle complete! 142 Gemfile dependencies, 184 gems now installed.
Gems in the groups 'development' and 'test' were not installed.
Bundled gems are installed into `./vendor/bundle`
1 installed gem you directly depend on is looking for funding.
  Run `bundle fund` for details
$ if [ -f yarn.lock ]; then yarn install; else CI=1 pnpm install; fi
 WARN  This project is configured to use v9.9.0 of pnpm. Your current pnpm is v9.1.4
Scope: all 19 workspace projects
Lockfile is up to date, resolution step is skipped
Already up to date
Done in 3.8s
$ LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all
discourse-chat-integration is already at latest compatible version
discourse-post-voting is already at latest compatible version
discourse-reactions is already at latest compatible version
discourse-rss-polling is already at latest compatible version
discourse-signatures is already at latest compatible version
discourse-whos-online is already at latest compatible version
docker_manager is already at latest compatible version
$ SKIP_POST_DEPLOYMENT_MIGRATIONS=1 bundle exec rake multisite:migrate
Multisite migrator is running using 1 threads
Migrating default
Seeding default
*** Bundling assets. This will take a while ***
$ bundle exec rake themes:update assets:precompile
Checking 'Blackout' for 'default'... up to date
Checking 'Custom Header Links' for 'default'... updating from 940d9d08 to 299a7eba
Building
Environment: production
building...
...[ConfigLoader]
...[Babel: discourse-widget-hbs > applyPatches]
...[Babel: @embroider/macros > applyPatches]
...[Babel: pretty-text > applyPatches]
...[Babel: discourse-common > applyPatches]
...[Babel: ember-source > applyPatches]
...[ember.js]
...[Babel: @glimmer/component > applyPatches]
...[Babel: @ember/legacy-built-in-components > applyPatches]
...[Babel: dialog-holder > applyPatches]
...[Babel: ember-cache-primitive-polyfill > applyPatches]
...[Babel: ember-on-resize-modifier > applyPatches]
...[Babel: float-kit > applyPatches]
...[Babel: select-kit > applyPatches]
...[@embroider/compat/app]
...[@embroider/webpack]
...[SourceMapConcat]
...[Babel: admin > applyPatches]
...[TerserWriter]
...[TerserWriter]
...[Babel: discourse-plugins > applyPatches]
...[TerserWriter]
...[TerserWriter]
WARNING: 319 deprecations encountered while compiling scss. (we cannot correct these until the Ruby SCSS pipeline is updated)
cleaning up
cleaning up...
Built project successfully. Stored in "dist/".
File sizes:
 - dist/assets/admin.js: 957.64 kB (159.22 kB gzipped)
 - dist/assets/browser-detect.js: 425 B (298 B gzipped)
 - dist/assets/browser-update.js: 1.51 kB (866 B gzipped)
 - dist/assets/chunk.25e35d3128e20a313ed3.d41d8cd9.js: 2.91 MB (963.17 kB gzipped)
 - dist/assets/chunk.289c5e793960b9d7e044.d41d8cd9.js: 58.57 kB (17.67 kB gzipped)
 - dist/assets/chunk.385f751d55b73db29793.d41d8cd9.js: 4.7 MB (1.05 MB gzipped)
 - dist/assets/chunk.4d8ec4e5eade9fb8fa6d.d41d8cd9.js: 522.49 kB (101.23 kB gzipped)
 - dist/assets/chunk.4f6721924e4132003bca.css: 139.49 kB (23.38 kB gzipped)
 - dist/assets/chunk.5769da02aa45256811b9.css: 20.97 kB (4.92 kB gzipped)
 - dist/assets/chunk.5769da02aa45256811b9.d41d8cd9.js: 209 B (188 B gzipped)
 - dist/assets/chunk.5ddbb05571dc3ff0c7ff.d41d8cd9.js: 449.61 kB (120.63 kB gzipped)
 - dist/assets/chunk.73a366a489bcf1d084a9.d41d8cd9.js: 6.5 kB (2.66 kB gzipped)
 - dist/assets/chunk.9229a63bfdbbd797c335.d41d8cd9.js: 5.36 kB (2.1 kB gzipped)
 - dist/assets/chunk.96f6a82d41b7ecdb46ff.d41d8cd9.js: 4.06 kB (1.83 kB gzipped)
 - dist/assets/chunk.9a4c7b62d1cdc227726d.d41d8cd9.js: 104.3 kB (46.21 kB gzipped)
 - dist/assets/chunk.9ae9bfd2e3a0346e65fe.d41d8cd9.js: 597.18 kB (162.61 kB gzipped)
 - dist/assets/chunk.9d4fa1cf0713b99ddc47.d41d8cd9.js: 40.92 kB (13.85 kB gzipped)
 - dist/assets/chunk.a12aa1448e5b03816d58.d41d8cd9.js: 6.65 kB (2.49 kB gzipped)
 - dist/assets/chunk.ce4f6b57aefd2813f407.d41d8cd9.js: 209 B (188 B gzipped)
 - dist/assets/chunk.ec4a3c77e03542b4b37f.d41d8cd9.js: 67.53 kB (12.56 kB gzipped)
 - dist/assets/chunk.f160741d1752972db397.d41d8cd9.js: 20.87 kB (8.13 kB gzipped)
 - dist/assets/chunk.f9f3bdbb1b89a4c7161b.d41d8cd9.js: 153 B (142 B gzipped)
 - dist/assets/discourse.css: 171 B (156 B gzipped)
 - dist/assets/discourse.d41d8cd98f00b204e9800998ecf8427e.css: 0 B
 - dist/assets/embed-application.js: 1.19 kB (574 B gzipped)
 - dist/assets/google-tag-manager.js: 526 B (357 B gzipped)
 - dist/assets/google-universal-analytics-v3.js: 654 B (403 B gzipped)
 - dist/assets/google-universal-analytics-v4.js: 461 B (298 B gzipped)
 - dist/assets/onpopstate-handler.js: 157 B (143 B gzipped)
 - dist/assets/pageview.js: 347 B (255 B gzipped)
 - dist/assets/plugins/automation_admin.js: 117.89 kB (15.8 kB gzipped)
 - dist/assets/plugins/chat.js: 788.59 kB (137.85 kB gzipped)
 - dist/assets/plugins/checklist.js: 3.81 kB (1.75 kB gzipped)
 - dist/assets/plugins/discourse-chat-integration.js: 1.29 kB (585 B gzipped)
 - dist/assets/plugins/discourse-chat-integration_admin.js: 35.66 kB (5.61 kB gzipped)
 - dist/assets/plugins/discourse-details.js: 1.25 kB (614 B gzipped)
 - dist/assets/plugins/discourse-lazy-videos.js: 6.31 kB (2.12 kB gzipped)
 - dist/assets/plugins/discourse-local-dates.js: 30.98 kB (8.36 kB gzipped)
 - dist/assets/plugins/discourse-post-voting.js: 44.89 kB (9.32 kB gzipped)
 - dist/assets/plugins/discourse-presence.js: 10.5 kB (2.35 kB gzipped)
 - dist/assets/plugins/discourse-reactions.js: 41.79 kB (9.3 kB gzipped)
 - dist/assets/plugins/discourse-rss-polling.js: 11.17 kB (2.14 kB gzipped)
 - dist/assets/plugins/discourse-signatures.js: 6.03 kB (1.43 kB gzipped)
 - dist/assets/plugins/discourse-whos-online.js: 16.35 kB (2.93 kB gzipped)
 - dist/assets/plugins/docker_manager_admin.js: 32.3 kB (6.49 kB gzipped)
 - dist/assets/plugins/footnote.js: 2.87 kB (1.25 kB gzipped)
 - dist/assets/plugins/poll.js: 91.92 kB (20.7 kB gzipped)
 - dist/assets/plugins/spoiler-alert.js: 3.27 kB (1.39 kB gzipped)
 - dist/assets/plugins/styleguide.js: 154.18 kB (21.22 kB gzipped)
 - dist/assets/print-page.js: 111 B (125 B gzipped)
 - dist/assets/publish.js: 294 B (212 B gzipped)
 - dist/assets/qunit-custom.css: 6.74 kB (1.89 kB gzipped)
 - dist/assets/qunit.css: 935.36 kB (132.29 kB gzipped)
 - dist/assets/scripts/discourse-boot.js: 390 B (270 B gzipped)
 - dist/assets/scripts/discourse-test-listen-boot.js: 122 B (106 B gzipped)
 - dist/assets/scripts/discourse-test-load-dynamic-js.js: 1.14 kB (601 B gzipped)
 - dist/assets/scripts/module-shims.js: 771 B (326 B gzipped)
 - dist/assets/scripts/start-app.js: 216 B (180 B gzipped)
 - dist/assets/splash-screen.js: 1.17 kB (554 B gzipped)
 - dist/assets/start-discourse.js: 495 B (338 B gzipped)
 - dist/assets/test-i18n.js: 587.25 kB (147.2 kB gzipped)
 - dist/assets/test-site-settings.js: 13.22 kB (4.86 kB gzipped)
 - dist/assets/vendor.d3163860318024d1a45415fcf58dbe4b.js: 440.54 kB (123.43 kB gzipped)
 - dist/javascripts/chart.js/3.5.1/chart.min.js: 188.37 kB (65.3 kB gzipped)
 - dist/javascripts/chartjs-plugin-datalabels/2.2.0/chartjs-plugin-datalabels.min.js: 12.94 kB (5.24 kB gzipped)
 - dist/javascripts/count.js: 1.44 kB (636 B gzipped)
 - dist/javascripts/embed-topics.js: 1.34 kB (631 B gzipped)
 - dist/javascripts/embed.js: 2.47 kB (1.01 kB gzipped)
 - dist/javascripts/magnific-popup/1.1.0/jquery.magnific-popup.min.js: 20.22 kB (7.37 kB gzipped)
 - dist/javascripts/media-optimization-worker.js: 5.01 kB (1.74 kB gzipped)
 - dist/javascripts/pikaday/1.8.2/pikaday.js: 42.54 kB (9.67 kB gzipped)
 - dist/javascripts/squoosh/mozjpeg_enc.js: 39.03 kB (10.81 kB gzipped)
 - dist/javascripts/squoosh/squoosh_resize.js: 4.53 kB (1.28 kB gzipped)
Purging temp files
Bundling assets
Compressing: locales/sq-d5028eb6deea56bd9ee8518ad94d664e1f726bc14ffe0caaef63306f53b3009b.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sq-d5028eb6deea56bd9ee8518ad94d664e1f726bc14ffe0caaef63306f53b3009b.js > /var/www/discourse/public/assets/locales/sq-d5028eb6deea56bd9ee8518ad94d664e1f726bc14ffe0caaef63306f53b3009b.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sq-d5028eb6deea56bd9ee8518ad94d664e1f726bc14ffe0caaef63306f53b3009b.js --output=/var/www/discourse/public/assets/locales/sq-d5028eb6deea56bd9ee8518ad94d664e1f726bc14ffe0caaef63306f53b3009b.js.br
Done 'locales/sq-d5028eb6deea56bd9ee8518ad94d664e1f726bc14ffe0caaef63306f53b3009b.js' : 0.15 secs
Compressing: locales/sr-d6dd306b86459d25e82af3d0bf3e96fe743b715c5d36062d05eac00b1762df7f.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sr-d6dd306b86459d25e82af3d0bf3e96fe743b715c5d36062d05eac00b1762df7f.js > /var/www/discourse/public/assets/locales/sr-d6dd306b86459d25e82af3d0bf3e96fe743b715c5d36062d05eac00b1762df7f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sr-d6dd306b86459d25e82af3d0bf3e96fe743b715c5d36062d05eac00b1762df7f.js --output=/var/www/discourse/public/assets/locales/sr-d6dd306b86459d25e82af3d0bf3e96fe743b715c5d36062d05eac00b1762df7f.js.br
Done 'locales/sr-d6dd306b86459d25e82af3d0bf3e96fe743b715c5d36062d05eac00b1762df7f.js' : 0.07 secs
Compressing: locales/sv-e88d1c38043c1939567d0202f9f313e0625593751202589210cf718b32df07ba.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sv-e88d1c38043c1939567d0202f9f313e0625593751202589210cf718b32df07ba.js > /var/www/discourse/public/assets/locales/sv-e88d1c38043c1939567d0202f9f313e0625593751202589210cf718b32df07ba.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sv-e88d1c38043c1939567d0202f9f313e0625593751202589210cf718b32df07ba.js --output=/var/www/discourse/public/assets/locales/sv-e88d1c38043c1939567d0202f9f313e0625593751202589210cf718b32df07ba.js.br
Done 'locales/sv-e88d1c38043c1939567d0202f9f313e0625593751202589210cf718b32df07ba.js' : 0.08 secs
Compressing: locales/sw-cf938de6ba0f9d850a33ac66d7f26de4a49422444e52d88fd40b93c0d5c23ee2.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sw-cf938de6ba0f9d850a33ac66d7f26de4a49422444e52d88fd40b93c0d5c23ee2.js > /var/www/discourse/public/assets/locales/sw-cf938de6ba0f9d850a33ac66d7f26de4a49422444e52d88fd40b93c0d5c23ee2.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sw-cf938de6ba0f9d850a33ac66d7f26de4a49422444e52d88fd40b93c0d5c23ee2.js --output=/var/www/discourse/public/assets/locales/sw-cf938de6ba0f9d850a33ac66d7f26de4a49422444e52d88fd40b93c0d5c23ee2.js.br
Done 'locales/sw-cf938de6ba0f9d850a33ac66d7f26de4a49422444e52d88fd40b93c0d5c23ee2.js' : 0.08 secs
Compressing: locales/te-f8a4f1f67736673d636c7e8eb5cd8290d859db2eb29a4168c0dc3752649dfaa7.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/te-f8a4f1f67736673d636c7e8eb5cd8290d859db2eb29a4168c0dc3752649dfaa7.js > /var/www/discourse/public/assets/locales/te-f8a4f1f67736673d636c7e8eb5cd8290d859db2eb29a4168c0dc3752649dfaa7.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/te-f8a4f1f67736673d636c7e8eb5cd8290d859db2eb29a4168c0dc3752649dfaa7.js --output=/var/www/discourse/public/assets/locales/te-f8a4f1f67736673d636c7e8eb5cd8290d859db2eb29a4168c0dc3752649dfaa7.js.br
Done 'locales/te-f8a4f1f67736673d636c7e8eb5cd8290d859db2eb29a4168c0dc3752649dfaa7.js' : 0.12 secs
Compressing: locales/th-222d5d388ffbc6029e8392b5ee428ff832dc9ee4aea816ab3e904b896dd3cd11.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/th-222d5d388ffbc6029e8392b5ee428ff832dc9ee4aea816ab3e904b896dd3cd11.js > /var/www/discourse/public/assets/locales/th-222d5d388ffbc6029e8392b5ee428ff832dc9ee4aea816ab3e904b896dd3cd11.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/th-222d5d388ffbc6029e8392b5ee428ff832dc9ee4aea816ab3e904b896dd3cd11.js --output=/var/www/discourse/public/assets/locales/th-222d5d388ffbc6029e8392b5ee428ff832dc9ee4aea816ab3e904b896dd3cd11.js.br
Done 'locales/th-222d5d388ffbc6029e8392b5ee428ff832dc9ee4aea816ab3e904b896dd3cd11.js' : 0.09 secs
Compressing: locales/tr_TR-8ef3d63d9494019ef50433deb4ef58562c0a359841603249402f17731f94d428.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/tr_TR-8ef3d63d9494019ef50433deb4ef58562c0a359841603249402f17731f94d428.js > /var/www/discourse/public/assets/locales/tr_TR-8ef3d63d9494019ef50433deb4ef58562c0a359841603249402f17731f94d428.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/tr_TR-8ef3d63d9494019ef50433deb4ef58562c0a359841603249402f17731f94d428.js --output=/var/www/discourse/public/assets/locales/tr_TR-8ef3d63d9494019ef50433deb4ef58562c0a359841603249402f17731f94d428.js.br
Done 'locales/tr_TR-8ef3d63d9494019ef50433deb4ef58562c0a359841603249402f17731f94d428.js' : 0.07 secs
Compressing: locales/ug-2d7ee49f6c043f7624cde981371c9dd15cdb0b2a6a85c7f7377caa92f2a37b64.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ug-2d7ee49f6c043f7624cde981371c9dd15cdb0b2a6a85c7f7377caa92f2a37b64.js > /var/www/discourse/public/assets/locales/ug-2d7ee49f6c043f7624cde981371c9dd15cdb0b2a6a85c7f7377caa92f2a37b64.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ug-2d7ee49f6c043f7624cde981371c9dd15cdb0b2a6a85c7f7377caa92f2a37b64.js --output=/var/www/discourse/public/assets/locales/ug-2d7ee49f6c043f7624cde981371c9dd15cdb0b2a6a85c7f7377caa92f2a37b64.js.br
Done 'locales/ug-2d7ee49f6c043f7624cde981371c9dd15cdb0b2a6a85c7f7377caa92f2a37b64.js' : 0.09 secs
Compressing: locales/uk-de8fa09197d111a47d9efd9b7aa982c46a412681769c3b27c61f4b39694cc7ff.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/uk-de8fa09197d111a47d9efd9b7aa982c46a412681769c3b27c61f4b39694cc7ff.js > /var/www/discourse/public/assets/locales/uk-de8fa09197d111a47d9efd9b7aa982c46a412681769c3b27c61f4b39694cc7ff.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/uk-de8fa09197d111a47d9efd9b7aa982c46a412681769c3b27c61f4b39694cc7ff.js --output=/var/www/discourse/public/assets/locales/uk-de8fa09197d111a47d9efd9b7aa982c46a412681769c3b27c61f4b39694cc7ff.js.br
Done 'locales/uk-de8fa09197d111a47d9efd9b7aa982c46a412681769c3b27c61f4b39694cc7ff.js' : 0.1 secs
Compressing: locales/ur-7df73552abb76d19d3d5841605ffb1f6542b30be974e3e37da53ab91a1a904c9.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ur-7df73552abb76d19d3d5841605ffb1f6542b30be974e3e37da53ab91a1a904c9.js > /var/www/discourse/public/assets/locales/ur-7df73552abb76d19d3d5841605ffb1f6542b30be974e3e37da53ab91a1a904c9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ur-7df73552abb76d19d3d5841605ffb1f6542b30be974e3e37da53ab91a1a904c9.js --output=/var/www/discourse/public/assets/locales/ur-7df73552abb76d19d3d5841605ffb1f6542b30be974e3e37da53ab91a1a904c9.js.br
Done 'locales/ur-7df73552abb76d19d3d5841605ffb1f6542b30be974e3e37da53ab91a1a904c9.js' : 0.09 secs
Compressing: locales/vi-c468ebde23ee57a1cd4160e83b18c147be17d83fd7113d10f17c04bfa4167caf.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/vi-c468ebde23ee57a1cd4160e83b18c147be17d83fd7113d10f17c04bfa4167caf.js > /var/www/discourse/public/assets/locales/vi-c468ebde23ee57a1cd4160e83b18c147be17d83fd7113d10f17c04bfa4167caf.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/vi-c468ebde23ee57a1cd4160e83b18c147be17d83fd7113d10f17c04bfa4167caf.js --output=/var/www/discourse/public/assets/locales/vi-c468ebde23ee57a1cd4160e83b18c147be17d83fd7113d10f17c04bfa4167caf.js.br
Done 'locales/vi-c468ebde23ee57a1cd4160e83b18c147be17d83fd7113d10f17c04bfa4167caf.js' : 0.08 secs
Compressing: locales/zh_CN-1e8954addf494f2be29df46332750e87f77655ed3129422cca3b08226eec59b0.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/zh_CN-1e8954addf494f2be29df46332750e87f77655ed3129422cca3b08226eec59b0.js > /var/www/discourse/public/assets/locales/zh_CN-1e8954addf494f2be29df46332750e87f77655ed3129422cca3b08226eec59b0.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/zh_CN-1e8954addf494f2be29df46332750e87f77655ed3129422cca3b08226eec59b0.js --output=/var/www/discourse/public/assets/locales/zh_CN-1e8954addf494f2be29df46332750e87f77655ed3129422cca3b08226eec59b0.js.br
Done 'locales/zh_CN-1e8954addf494f2be29df46332750e87f77655ed3129422cca3b08226eec59b0.js' : 0.07 secs
Compressing: locales/zh_TW-78104a741f68651e0f485ae09a64d0713cc0c933589282cf7873fa9b8859176f.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/zh_TW-78104a741f68651e0f485ae09a64d0713cc0c933589282cf7873fa9b8859176f.js > /var/www/discourse/public/assets/locales/zh_TW-78104a741f68651e0f485ae09a64d0713cc0c933589282cf7873fa9b8859176f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/zh_TW-78104a741f68651e0f485ae09a64d0713cc0c933589282cf7873fa9b8859176f.js --output=/var/www/discourse/public/assets/locales/zh_TW-78104a741f68651e0f485ae09a64d0713cc0c933589282cf7873fa9b8859176f.js.br
Done 'locales/zh_TW-78104a741f68651e0f485ae09a64d0713cc0c933589282cf7873fa9b8859176f.js' : 0.07 secs
Compressing: admin-2b80ebbadb6a72df33135eb168fb040c9ee5d0c86fda5e5e1c15eda301a32d5f.js
gzip -f -c -9 /var/www/discourse/public/assets/admin-2b80ebbadb6a72df33135eb168fb040c9ee5d0c86fda5e5e1c15eda301a32d5f.js > /var/www/discourse/public/assets/admin-2b80ebbadb6a72df33135eb168fb040c9ee5d0c86fda5e5e1c15eda301a32d5f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/admin-2b80ebbadb6a72df33135eb168fb040c9ee5d0c86fda5e5e1c15eda301a32d5f.js --output=/var/www/discourse/public/assets/admin-2b80ebbadb6a72df33135eb168fb040c9ee5d0c86fda5e5e1c15eda301a32d5f.js.br
Done 'admin-2b80ebbadb6a72df33135eb168fb040c9ee5d0c86fda5e5e1c15eda301a32d5f.js' : 0.09 secs
Skipping: chunk.020b1d74ca2244460d62.d41d8cd9.js already compressed
Skipping: chunk.05826de462450dc5e2e4.d41d8cd9.js already compressed
Compressing: chunk.0df7577d4ac976c1bdcf.d41d8cd9.js
pnpm terser '/var/www/discourse/public/assets/_chunk.0df7577d4ac976c1bdcf.d41d8cd9.js' -m -c -o '/var/www/discourse/public/assets/chunk.0df7577d4ac976c1bdcf.d41d8cd9.js' --source-map "base='/var/www/discourse/public/assets',root='/assets',url='chunk.0df7577d4ac976c1bdcf.d41d8cd9.js.map',includeSources=true"
rake aborted!
Errno::ENOENT: No such file or directory @ rb_file_s_size - /var/www/discourse/public/assets/chunk.0df7577d4ac976c1bdcf.d41d8cd9.js (Errno::ENOENT)
/var/www/discourse/lib/tasks/assets.rake:297:in `size'
/var/www/discourse/lib/tasks/assets.rake:297:in `block (6 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:250:in `log_task_duration'
/var/www/discourse/lib/tasks/assets.rake:289:in `block (5 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:240:in `block in concurrent?'
/var/www/discourse/lib/tasks/assets.rake:288:in `block (4 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:271:in `each'
/var/www/discourse/lib/tasks/assets.rake:271:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:240:in `concurrent?'
/var/www/discourse/lib/tasks/assets.rake:267:in `block (2 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:266:in `block in <main>'
/var/www/discourse/lib/tasks/assets.rake:332:in `block in <main>'
Tasks: TOP => assets:precompile:compress_js
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:210:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:111:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/commands/runner/runner_command.rb:41:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/commands/runner/runner_command.rb:41:in `block in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4/lib/active_support/execution_wrapper.rb:92:in `wrap'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/commands/runner/runner_command.rb:40:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command/base.rb:178:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command/base.rb:73:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command.rb:71:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command.rb:149:in `with_argv'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command.rb:69:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/commands.rb:18:in `<main>'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:74:in `require'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:74:in `block (2 levels) in replace_require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Spinning up 7 Unicorn worker(s) that were stopped initially
Thank you
Does it work if you re-run the update?
It’s interesting that chunk.0df757 is not listed as one of the ember-cli assets in this log. Are you using a standard install? Is there any chance that another update was running at the same time?
Hi David,
Yes it’s the standard install. Not possible of multiple updates running, its been like this for a couple of months now. Update failing that is
Have you tried running a command-line rebuild? (./launcher rebuild app)
+ /usr/bin/docker run --shm-size=512m -d --restart=always -e LANG=en_US.UTF-8 -e RAILS_ENV=production -e UNICORN_WORKERS=8 -e UNICORN_SIDEKIQS=1 -e RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000 -e RUBY_GC_HEAP_INIT_SLOTS=400000 -e RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5 -e DISCOURSE_DB_SOCKET=/var/run/postgresql -e DISCOURSE_DB_HOST= -e DISCOURSE_DB_PORT= -e LC_ALL=en_US.UTF-8 -e LANGUAGE=en_US.UTF-8 -e DISCOURSE_FORCE_HTTPS=true -e DISCOURSE_HOSTNAME=forum.hhf.technology -e DISCOURSE_DEVELOPER_EMAILS=REDACTED  -e DISCOURSE_SMTP_ADDRESS=smtp.mailgun.org -e DISCOURSE_SMTP_PORT=587 -e DISCOURSE_SMTP_USER_NAME=postmaster@forum.hhf.technology -e DISCOURSE_SMTP_PASSWORD=REDACTED  -e DISCOURSE_NOTIFICATION_EMAIL=noreply@forum.hhf.technology -h cloudpanelv6-app -e DOCKER_HOST_IP=172.17.0.1 --name app -t -v /docker/discourse/shared/standalone:/shared -v /docker/discourse/shared/standalone/log/var-log:/var/log --mac-address 02:95:e4:11:44:55 local_discourse/app /sbin/boot
docker: "specify mac-address per network" requires API version 1.44, but the Docker daemon API version is 1.43.
See 'docker run --help'.
Failed to restart the container.
somewhat similar situation
Not the same problem - better to start a new topic. Looks like your Docker is out of date. If you can’t update it, maybe your OS is out of date.
sure will start a new topic. Docker is also not out of date and neither the OS.
issues solved. so didn’t start a new topic. thanks. was a tricky one.
Hi @david
I just did the CLI rebuild successfully.
One thing the logs noted was:
Post-install message from i18n:
PSA: I18n will be dropping support for Ruby < 3.2 in the next major release (April 2025), due to Ruby's end of life for 3.1 and below (https://endoflife.date/ruby). Please upgrade to Ruby 3.2 or newer by April 2025 to continue using future versions of this gem.
Our ruby version is 3.0.2p107 (2021-07-07 revision 0db68f0233) [x86_64-linux-gnu]
What are the steps to upgrade this before April 2025? I read somewhere else that the ruby version might be included with Discourse and thus might update when necessary during a Discourse update.
If you use a standard install, then the Ruby version should already be much newer than that.
Can you try running
cd /var/discourse
git status
Yeah, this is the output:
On branch main
Your branch is up to date with 'origin/main'.
nothing to commit, working tree clean
Note that this was a fresh install done June 16th 2024
How did you check this Ruby version? Were you inside the Discourse docker container? Or on the host?
(The one inside the container is the only one which matters for Discourse)
