השבתת שרשראות שיחה ב-DM's
סיכום מבוסס בינה מלאכותית
Users are requesting to disable chat threads by default in Direct Messages (DMs), citing confusion and unnecessary complexity. MarcP initiated the discussion, noting that threads are automatically enabled in new DMs — contrary to channels, which default to no threading. sam confirmed the inconsistency and suggested flipping the default to “no threading” for DMs, allowing users to enable it per conversation if needed. Jagster and nathank echoed frustrations, including UI bugs (e.g., unread thread indicators not displaying properly) and usability issues, especially with AI chats. donaldsoncd and fokx highlighted navigation difficulties and advocated for a global disable option. Jonathan5 linked the issue to low chat adoption due to clutter. In response, lindsey confirmed the team will change the default to threading off for new DMs to align with channel behavior. davidb noted the fix is implemented via a commit and will apply to new DMs only; existing DMs remain unchanged but can be manually adjusted.
When I reply to a particular message, Discourse automatically makes this a thread. We can disable this per channel/chat basis..
How can we stop this behaviour from happening in DM’s by default (or completely)? This is very aggressive and actually making simple DM’s very complex to follow.
10 לייקים
Hey @MarcP, thanks for starting this topic . We do not currently have a way to automatically disable threads in new DM or group chat channels.
I’ve moved it to Contribute > Feature so that we can better gauge interest in this functionality.
3 לייקים
Chat threads for DMs was completed with only 2 votes. I like to think we deserve a OFF setting for threads by default at a minimum..
2 לייקים
I am confused though:
This is configurable per DM and default off?
לייק 1
This, and my experience can not confirm that.
Which aligns with what was said in the request topic to enable threads in DMs.
Yeah @lindsey I feel like our default is flipped here.
When you create a channel we default to “no threading”
When you create a DM now we default to “yes threading”. (all old DMs you have have “no threading” for extra confusion)
At a minimum I wonder if we can default to no threading, should be tiny change. Then people who need threading in a DM can click the button to enable it?
6 לייקים
Don’t mind the language. I trust you understand what is going on.
This is a private chat with an AI persona, and threading is disabled.
And another issue is this:
Yes, the sidebar tells I have unread thread, but it doesn’t show it.
But this an issue with AI. Chatting with real persons doesn’t create threads. I asked that some times ago and then I was told that thing now just are this way with AI. And sorry, but I really dislike that way and that’s why no one uses chat anymore with AI in my forum.
I know, I know. This is a bug or an UI issue — but I trust moderators know what to do :smirking_face:
I’ve just encountered this again today - and I really want to disable threading for DMs by default. But can’t!!!
The vast majority of our DMs (including group chats) are well served by a single thread. Occasionally threading would be helpful, in which case we can turn it on for that chat conversation.
The present default seems bananas. I agree with Sam!
Has this fallen off the radar? I note that there are 7 votes on this Topic (which is quite a few in this category).
5 לייקים
I just ran into this same issue because I couldn’t figure out why I had a “My Threads” thing visible in my side navbar:
I thought it was a bug (after having read this topic which said that it shouldn’t be showing up unless I have threads enabled), but then I dug into my DMs and found that my most recent DM had threading enabled. I’m guessing that this was on by default because I wouldn’t have chosen to have it on.
(It’s kind of a separate thing, but if threads are turned on and it shows up in the navbar, it might make sense for it to appear below "DMs” instead of so high up.)
2 לייקים
+1 על התכונה הזו.
בסביבת רשת איטית, ניווט בין הודעות ישירות ראשיות לשרשורים שונים יכול להיות מייגע. כמו כן, אני חושב שהצ’אט צריך להציע אפשרות להשבית שרשורים עבור כל המשתמשים באופן גלובלי.
2 לייקים
I’d like to have threads off by default too. See Is it possible to get rid of the "My Threads" link/button?. If chat isn’t getting used a lot it’s just an extra complication and it’s unclear (in that same scenario) what the My Threads icon/button is for.
3 לייקים
תודה על המשוב כאן, חברים — אנחנו הולכים להחליף את ברירת המחדל כאן כך שהודעות ישירות (DMs) יכבו את השרשור כברירת מחדל, כך שזה יתאים טוב יותר לברירות המחדל של הערוצים. נשתף עדכון כאן לאחר שהשינוי יושלם.
7 לייקים
This should be solved with this change:
https://github.com/discourse/discourse/commit/532d656d17649a76471dabb7709dac494fef5dc8
It’s worth noting that this will take effect for all new DM chats initiated. Existing chats are not changed but threads can still be turned off manually within each channel’s settings.
7 לייקים
נושא זה נסגר אוטומטית לאחר 3 ימים. לא ניתן להוסיף תגובות חדשות.
