DM에서 채팅 스레드 비활성화
When I reply to a particular message, Discourse automatically makes this a thread. We can disable this per channel/chat basis..
How can we stop this behaviour from happening in DM’s by default (or completely)? This is very aggressive and actually making simple DM’s very complex to follow.
10개의 좋아요
안녕하세요, @MarcP. 이 주제를 시작해 주셔서 감사합니다. 현재 DM이나 그룹 채팅 채널에서 스레드를 자동으로 비활성화할 수 있는 방법은 없습니다.
이 기능을 얼마나 많은 분들이 원하는지 더 잘 파악할 수 있도록 Contribute > Feature 채널로 옮겼습니다.
3개의 좋아요
Chat threads for DMs was completed with only 2 votes. I like to think we deserve a OFF setting for threads by default at a minimum..
2개의 좋아요
I am confused though:
This is configurable per DM and default off?
1개의 좋아요
This, and my experience can not confirm that.
Which aligns with what was said in the request topic to enable threads in DMs.
Yeah @lindsey I feel like our default is flipped here.
When you create a channel we default to “no threading”
When you create a DM now we default to “yes threading”. (all old DMs you have have “no threading” for extra confusion)
At a minimum I wonder if we can default to no threading, should be tiny change. Then people who need threading in a DM can click the button to enable it?
6개의 좋아요
Don’t mind the language. I trust you understand what is going on.
This is a private chat with an AI persona, and threading is disabled.
And another issue is this:
Yes, the sidebar tells I have unread thread, but it doesn’t show it.
But this an issue with AI. Chatting with real persons doesn’t create threads. I asked that some times ago and then I was told that thing now just are this way with AI. And sorry, but I really dislike that way and that’s why no one uses chat anymore with AI in my forum.
I know, I know. This is a bug or an UI issue — but I trust moderators know what to do :smirking_face:
I’ve just encountered this again today - and I really want to disable threading for DMs by default. But can’t!!!
The vast majority of our DMs (including group chats) are well served by a single thread. Occasionally threading would be helpful, in which case we can turn it on for that chat conversation.
The present default seems bananas. I agree with Sam!
Has this fallen off the radar? I note that there are 7 votes on this Topic (which is quite a few in this category).
5개의 좋아요
I just ran into this same issue because I couldn’t figure out why I had a “My Threads” thing visible in my side navbar:
I thought it was a bug (after having read this topic which said that it shouldn’t be showing up unless I have threads enabled), but then I dug into my DMs and found that my most recent DM had threading enabled. I’m guessing that this was on by default because I wouldn’t have chosen to have it on.
(It’s kind of a separate thing, but if threads are turned on and it shows up in the navbar, it might make sense for it to appear below "DMs” instead of so high up.)
2개의 좋아요
+1 on this feature.
In slow network environment, navigating between main DM and different threads can be a pain. Also I think chat should offer an option to disable thread for all users globally.
2개의 좋아요
I’d like to have threads off by default too. See Is it possible to get rid of the "My Threads" link/button?. If chat isn’t getting used a lot it’s just an extra complication and it’s unclear (in that same scenario) what the My Threads icon/button is for.
3개의 좋아요
Thanks for the feedback here, folks — we’re going to switch the default here so that DMs have threading off by default so it better matches the channel defaults. We’ll share an update here once that change is complete.
7개의 좋아요
This should be solved with this change:
https://github.com/discourse/discourse/commit/532d656d17649a76471dabb7709dac494fef5dc8
It’s worth noting that this will take effect for all new DM chats initiated. Existing chats are not changed but threads can still be turned off manually within each channel’s settings.
7개의 좋아요
This topic was automatically closed after 3 days. New replies are no longer allowed.
