Chat-threads in DM's uitschakelen
When I reply to a particular message, Discourse automatically makes this a thread. We can disable this per channel/chat basis..
How can we stop this behaviour from happening in DM’s by default (or completely)? This is very aggressive and actually making simple DM’s very complex to follow.
Hey @MarcP, thanks for starting this topic . We do not currently have a way to automatically disable threads in new DM or group chat channels.
I’ve moved it to Contribute > Feature so that we can better gauge interest in this functionality.
Chat threads for DMs was completed with only 2 votes. I like to think we deserve a OFF setting for threads by default at a minimum..
I am confused though:
This is configurable per DM and default off?
This, and my experience can not confirm that.
Which aligns with what was said in the request topic to enable threads in DMs.
Yeah @lindsey I feel like our default is flipped here.
When you create a channel we default to “no threading”
When you create a DM now we default to “yes threading”. (all old DMs you have have “no threading” for extra confusion)
At a minimum I wonder if we can default to no threading, should be tiny change. Then people who need threading in a DM can click the button to enable it?
Don’t mind the language. I trust you understand what is going on.
This is a private chat with an AI persona, and threading is disabled.
And another issue is this:
Yes, the sidebar tells I have unread thread, but it doesn’t show it.
But this an issue with AI. Chatting with real persons doesn’t create threads. I asked that some times ago and then I was told that thing now just are this way with AI. And sorry, but I really dislike that way and that’s why no one uses chat anymore with AI in my forum.
I know, I know. This is a bug or an UI issue — but I trust moderators know what to do :smirking_face:
I’ve just encountered this again today - and I really want to disable threading for DMs by default. But can’t!!!
The vast majority of our DMs (including group chats) are well served by a single thread. Occasionally threading would be helpful, in which case we can turn it on for that chat conversation.
The present default seems bananas. I agree with Sam!
Has this fallen off the radar? I note that there are 7 votes on this Topic (which is quite a few in this category).
I just ran into this same issue because I couldn’t figure out why I had a “My Threads” thing visible in my side navbar:
I thought it was a bug (after having read this topic which said that it shouldn’t be showing up unless I have threads enabled), but then I dug into my DMs and found that my most recent DM had threading enabled. I’m guessing that this was on by default because I wouldn’t have chosen to have it on.
(It’s kind of a separate thing, but if threads are turned on and it shows up in the navbar, it might make sense for it to appear below "DMs” instead of so high up.)
+1 voor deze functie.
In een omgeving met een trage netwerkverbinding kan het navigeren tussen de hoofd-DM en verschillende threads pijnlijk zijn. Ik denk ook dat de chat een optie moet bieden om threads voor alle gebruikers wereldwijd uit te schakelen.
I’d like to have threads off by default too. See Is it possible to get rid of the "My Threads" link/button?. If chat isn’t getting used a lot it’s just an extra complication and it’s unclear (in that same scenario) what the My Threads icon/button is for.
Bedankt voor de feedback, allemaal — we gaan de standaardinstelling hier wijzigen, zodat DMs standaard geen threading hebben, zodat dit beter overeenkomt met de standaardinstellingen van kanalen. We delen hier een update zodra die wijziging is voltooid.
This should be solved with this change:
https://github.com/discourse/discourse/commit/532d656d17649a76471dabb7709dac494fef5dc8
It’s worth noting that this will take effect for all new DM chats initiated. Existing chats are not changed but threads can still be turned off manually within each channel’s settings.
Dit onderwerp werd automatisch gesloten na 3 dagen. Nieuwe reacties zijn niet meer toegestaan.
