Het aanpassen van de kernkleuren zoals var(--secondary)
Is there any way to change colors like var(--secondary) which are used in various places around the site? In the color settings in customize you can change the “secondary” color but this seems to have no affect on var(--secondary)
Thanks!
I don’t know what you are doing, but var(–secondary) working for me:
code:
browser:
Let’s edit tertiary:
mmmm … jaffa:
If it were me, I’d have the problem you describe because I was changing one color scheme in the UX while using another in my theme component.
Your mileage may vary.
Here’s an example:
It seems that these vars are not configurable. This is the copy / paste from my colors config:
"HT Colors": {
  "primary": "142546",
  "secondary": "FEF9F0",
  "tertiary": "4A7FE5",
  "quaternary": "FBC379",
  "header_background": "ffffff",
  "header_primary": "142546",
  "highlight": "ffff4d",
  "danger": "e45735",
  "success": "009900",
  "love": "fa6c8d",
  "hover": "ebf0f9",
  "selected": "dee6f6"
It seems like there must be some other way to set the color vars used by badges, etc.
